Old 10-12-2014, 12:30 AM   #1
littlevictories
cts-v oil pump pickup into '99 ls1 pump
I googled and searched, but I can't seem to find a final word.
I'm putting a CTS-V pan and pickup onto a 5.3 using a pump from a '99 LS1 (part # 12556436)
Which color o-ring should I use? Thanks.
DD
littlevictories is offline   Reply With Quote
Old 10-14-2014, 01:45 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: cts-v oil pump pickup into '99 ls1 pump
Use the ring that comes with the tube....you should be ok....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-14-2014, 10:48 PM   #3
littlevictories
here's the application chart I found off Tech
BLUE SEAL
Specifics:
* Oil Pick-Up Tube O-Ring ea.
* Chevy/GMC Pick-Up (1999-2000 LS V8) 1st design
* F-Body (1998-2002)
* Cadillac CTS-V (2004-2007)
* Corvette (1997-2008)
* Thickness = 3.55mm (0.140")
ID = 23.60mm (0.930")
GM Oil Pick-Up Tube O-Ring (2nd Design)
12584922
RED SEAL
Specifics:
* Chevy/GMC Pick-Up (1999-2000 LS V8 engines with 2nd design pick-up tube)
* Trailblazer (2003-2008 With LS V8 engine)
* Hummer H2 (2003-2008)
* Hummer H3 (2008 With LS V8 engine)
* Chevy/GMC Pick-Up (2001-2008 LS V8 engines)
* W- Body (2006-2008 With LS V8 engine - Impala, Lacrosse, Grand Prix)
* Thickness = 4.20mm (0.165")
ID = 20.69mm (0.815")
which is not very useful to me, since the felpro kit comes with red, green and black o-rings…not the blue one indicated above.
DD
Old 10-16-2014, 08:52 PM   #4
crazy longhorn
I used the blue seal, that came with the "hotrod pan kit"....no issues? mine is running a 2000/5.3. longhorn
