Old 10-12-2014, 04:10 PM   #1
62 bigwindow
62 bigwindow's Avatar
66 GMC rear u bolts
Any of you guys know where I can find a shorter set of rear u bolts
I removed a couple leaf springs to get the height I wanted and of course now the u bolts are too long....
62 bigwindow is offline   Reply With Quote
Old 10-12-2014, 04:36 PM   #2
bama63
bama63's Avatar
Re: 66 GMC rear u bolts
if your bolts are in good condition tighten them down and cut them off, if not autozone keeps them in stock
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 10-12-2014, 04:56 PM   #3
62 bigwindow
Thats not an option since they arent threaded far enough up to tighten since the leafs have been removed, And they are not round at the top like most applications they are square since the leafs are on top
Old 10-12-2014, 05:30 PM   #4
turbohounds
New U-bolts was my project today as well. O'Reilly's had different sizes they could order - I'd try your local parts store and see what they can come up with for you.
turbohounds is offline   Reply With Quote
Old 10-12-2014, 06:52 PM   #5
pimpston65
pimpston65's Avatar
can you thread the square u-bolts higher, with a threading tool?
pimpston65 is offline   Reply With Quote
Old 10-12-2014, 06:59 PM   #6
rickywideglide
rickywideglide's Avatar
see if there is a spring shop around for big trucks, theres one here locally that probably would ship. R and S spring
rickywideglide is offline   Reply With Quote
