10-12-2014, 06:25 PM | #1 |
Fuel sender
Has anyone purchased one of these from Dolphin? Mine has a large spring with it, not sure where it's used
10-13-2014, 09:12 AM | #2 |
Re: Fuel sender
Send me a pic of what you have and I will compare it to the one I just purchased
10-13-2014, 09:21 AM | #3 |
Re: Fuel sender
It's a big spring about 6" x 2"
10-13-2014, 11:20 AM | #4 |
Re: Fuel sender
This is what I got, spring in the middle. There's a water temp sender to the left of clocks, where's that screw in? Thanks
10-13-2014, 11:35 AM | #5 |
Re: Fuel sender
Well, looking on their website sure isn't any help. I'd just contact them and ask.
10-13-2014, 12:14 PM | #6 |
Re: Fuel sender
The "water temp sender" should screw in the top rear of the head. On the drivers side above the rear intake port. If you have a valve cover with 4 screws, it will be beside the rear left one. Assuming you have a straight 6, since you haven't given us much info.
As for the spring ???? There wasn't a ball with it was there? Could be part of an anti back flow device. Most fuel tanks have a ball in the neck of the tank that, will close it off if the vehicle flips to prevent fuel pouring out. |
10-13-2014, 12:18 PM | #7 |
Re: Fuel sender
Ok thanks Hogger I'll have a look. Just been told the spring came with the gauges not the sender
10-13-2014, 02:15 PM | #8 |
Re: Fuel sender
Yoshi
Temp sender either goes in the head between spark plugs 1 and 3. If not you can screw it into a coolant port. On the pic of your engine they are on the front of the manifold |
10-13-2014, 03:01 PM | #9 |
Re: Fuel sender
Head temp is more accurate, when I moved mine from intake jacket to head the gauge read about 10-12 degrees higher.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
10-13-2014, 07:38 PM | #10 |
Re: Fuel sender
Same sender as mine. No spring. No spring in the kit either
10-16-2014, 03:42 PM | #11 |
Re: Fuel sender
Sender won't fit in the hole in my tank
yoshi's 49 project |
10-16-2014, 04:08 PM | #12 |
Re: Fuel sender
Will the float fit? The sender is universal and you have to cut it to size. See dolphin site for instructions
10-16-2014, 04:09 PM | #13 |
Re: Fuel sender
The plate at the top is too big
10-16-2014, 04:36 PM | #14 |
Re: Fuel sender
The round plate with 5 holes in it to secure it to the tank?
10-16-2014, 04:38 PM | #15 |
Re: Fuel sender
Yeah it's too big for the hole in my tank
10-16-2014, 05:11 PM | #16 |
Re: Fuel sender
Pictures would be REALLY helpful.
That plate is supposed to be too big, so your sending unit doesn't fall into the tank, and has a way to be secured to the tank. Set it in, line up the holes and secure it with the screws. Almost sounding like a troll. |
10-16-2014, 05:18 PM | #17 |
Re: Fuel sender
Try & get some photos tomorrow, but it'll still be too big to fit in the hole
10-17-2014, 01:31 PM | #18 |
Re: Fuel sender
Yoshi
Or email me some pics of your tank top and show what doesn't fit. Is your tank stock? mbejcek@comcast.net. |
10-17-2014, 01:55 PM | #19 |
Re: Fuel sender
No sorry tank is under rear bed
10-17-2014, 02:22 PM | #20 |
Re: Fuel sender
May seem like a dumb question but could you possibly be looking and the opening for the fuel lines? I believe that opening is smaller?
10-17-2014, 02:24 PM | #21 |
Re: Fuel sender
Eh?
10-18-2014, 05:37 PM | #22 |
Re: Fuel sender
As you can see its a little bit bigger 2 3/4" compared to the tank hole which is 2 19/32. thinking about it I'm gonna remove the plate with the holes in it & reduce it a little so it will fit in
10-18-2014, 07:45 PM | #23 |
Re: Fuel sender
I think you've got something wrong there.
10-18-2014, 08:05 PM | #24 |
Re: Fuel sender
Let's see a picture of the entire top of the tank
10-18-2014, 08:52 PM | #25 |
Re: Fuel sender
The hole in the picture is for sending unit that is held in place with a twist lock type ring, not screw mounted unit. Google "twist lock sending unit" to get an idea of what they look like. I have no clue what the application is or will work.
