10-12-2014, 09:20 PM | #1 |
K30 center caps
I am going to buy aluminum wheels for a K30 SRW (single rear wheel) but I cannot find any info on the correct size center caps, I don't want them sticking out any farther then needed, the fronts will be open for the Dana 60. What is the correct size and length? I will be using Alcoa brand caps. Thanks!
10-13-2014, 09:29 PM | #2 |
Re: K30 center caps
10-14-2014, 07:25 AM | #3 |
Re: K30 center caps
I always left mine open front and back. Too cheap to buy some caps I suppose.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
10-14-2014, 11:44 AM | #4 |
Re: K30 center caps
the center caps on my K30 are 4 5/8". length?-personal preference...
10-14-2014, 12:00 PM | #5 |
Re: K30 center caps
Thank you! I just need to make sure I order ones that will be long enough without getting ones that are any longer then need be.
10-14-2014, 07:56 PM | #6 |
Re: K30 center caps
That size wheel are you ordering? The backspace, combined with the width will determin how much distance from the hub face to the edge of the wheel.ie: 15x6" wheel, 3" backspace, you end up with ~2 3/4" before the cap sticks beyond the edge of the wheel. Get a 15x10" wheel with the same 3" back space and you have almost 7" of space to stick a cap.
Have you got a full or semi-floater? Get a cap long enough to clear the axle. Otherwise, just get the shortest one they have if you don't like tall center caps. Alex. |
10-14-2014, 08:04 PM | #7 |
Re: K30 center caps
Alcoa Classic Single Wheel 16" x 7" 8-6.5" bolt circle, 5.155" hub bore, 4.290" backspace inches, 0.250" offset
Does that help? Going on 4x4 K30 so need the open front caps and I would think they will need to be pretty long as the lockouts on the Dana 60 stick out a good ways. Rear is the standard Corp 14 bolt full floater that came in all the 3/4 and 1tons for years. Thanks for any help, never knew finding center caps would be so hard! |
10-15-2014, 09:05 PM | #8 |
Re: K30 center caps
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
10-15-2014, 09:22 PM | #9 |
Re: K30 center caps
I regret ordering my wheels from Southwest wheel, they have no idea what they are doing! I will pay more to avoid them in the feature!
They have no idea what lug nuts our trucks take OR what center caps fit, what a joke. I had to tell them what their screw up was and what lugs I needed as well as what model center caps to order. I talked to both Jeff and Derek there. Now I get to send them back and wait for them to send me the correct parts... Last edited by Kinze; 10-15-2014 at 09:28 PM. |
10-18-2014, 10:04 PM | #10 |
Re: K30 center caps
Are 4in. deep center caps going to fit or will I need deeper ones?
10-19-2014, 12:01 AM | #11 |
Re: K30 center caps
four inch will be fine. mine are 4 5/8's o.d. & 4" long (14b ff)
