10-12-2014, 11:24 PM | #1 |
Rear End question. 1974 12bolt into a 62 swb
I keep reading that the 70-71 12 bolt is 1.5 inches wider than the stock diff. I have a 74 truck that is my donor for the front suspension and would like to use the rear also to keep everything 5x5. Will it fit? Or is the 74 wider? I'm not to concerned with mounts and stuff. That stuff I can change. I'm not close to my parts truck to take a measurement right now and thought someone might know.
Thanks in advance. Aaron
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
10-13-2014, 12:32 AM | #2 |
60-66 Nut
Re: Rear End question. 1974 12bolt into a 62 swb
The original HO32 differential under your '62 is 62" wide. The truck 12 bolts from '71-'82 are 63.5" wide. The truck 10 bolts from '80-'87 are also 63.5" wide.
10-13-2014, 12:41 AM | #3 |
Thanks capt. That's exactly what I needed to know. It's already got the newer 12 under it so I can just swap axles. pERFECT !
