Old 10-13-2014, 08:20 AM   #1
BrianG
BrianG's Avatar
Question about 'brackets' on New Replacement Grill Assy
I am planning to purchasing a replacement outer grill for me 69 when it comes back from the body shop. I will be buying the more expensive one with the letters stamped into it. Can anyone tell me if the steel brackets that are rivited on to the oem outer grills come on these replacement items, or do I need to keep the old brackets and re-rivet them to the new grill? These would be the long thin steel brackets where the outer grill bolts to the fenders.
BrianG is offline   Reply With Quote
Old 10-13-2014, 08:56 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Question about 'brackets' on New Replacement Grill Assy
I don't think they come with it and are hard to find. SAVE everything till yours is all put together. I bought a guys old grill from his wife while he was in Iraq and looking at his new one it was clear he had to use the brackets from the one I bought. Mine was trash any way so reuse of the brackets was not a problem. Now I need another grill for my second truck and man it is hard to find those brackets without having to shell out for a bad looking grill I will throw away anyway.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-13-2014, 10:58 AM   #3
FirstOwner69
FirstOwner69's Avatar
Here's an ebay search link to some fasteners that replicate the look of the original grille rivets. I used these and am pleased with the result. However, I don't recall which size. The heads on mine are bit larger than I like, so I'd probably go with the 8s to be safe.
http://www.ebay.com/sch/i.html?_odkw...ts&_sacat=6030
Here's a picture that shows the more prominent "rivets" painted black above and below the headlight.
FirstOwner69 is offline   Reply With Quote
Old 10-13-2014, 01:06 PM   #4
BrianG
BrianG's Avatar
Thanks for the help guys! I'll keep my old brackets and will order some of those rivet/bolts when the time comes.
