Old 10-13-2014, 12:03 PM   #1
Zackarymc
Porterbuilt plans
Do we get a fourm member discount? ALso anyone used their stock control arms? Says you can (ive already dumped a bunch in moog parts). If using your stock arms does it still lay frame?
Zackarymc is offline   Reply With Quote
Old 10-13-2014, 04:10 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt plans
Currently not running any discounts.
Stock uppers will work from 63-87 C10... may need a little trimming of the stamped steel around the bushing ends (mainly on the 73-87 frame).
Lowers from 73-87 C10 will work on the Level 3 (Extreme) Version 5. Must remove the factory cross-shaft and may need a little trimming on the bushings.
May or may not lay frame... depends on tire size, and spindle. Be prepared to recess the bag into the factory arm if running large diameter rubber.
If you have more questions feel free to shoot us an email at sales@pbfab.com.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-13-2014, 06:29 PM   #3
Zackarymc
29" tall tire ... 15" white walls .... thanks for the reply
