Old 10-13-2014, 12:34 PM   #1
JohnHavla
1972 K20 Rear Axle Washer
Sorry but I need a little help to ID a part.
I pulled my rear axle and drum assy on saturday to check my brakes. Everything went fine. However, I noticed the keyed and toothed washer (maybe a thrust washer)? had a few broken teeth. This is the washer between the rear axle bearings.
Does anyone know the correct name of this part?
Does anyone know where to get replacements?
Thanks as always,
John
JohnHavla is offline   Reply With Quote
Old 10-13-2014, 02:23 PM   #2
Bigdav160
Bigdav160's Avatar
Re: 1972 K20 Rear Axle Washer
For a 3/4 ton correct? As long as you can match up and bend the tangs over you're good. It a locknut retainer
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-13-2014, 02:28 PM   #3
JohnHavla
That's the part! My problem is some of the tangs were bent. One was barely hanging on. I will order a couple of new ones just to be safe. Thanks much!
Old 10-13-2014, 03:18 PM   #4
JohnHavla
Amazing guys at quad4x4. Already ordered!
