10-13-2014, 04:40 PM | #1 |
Can't reach hex bolt on headers
I'm trying to remove the headers from my 350 small block to replace the headers and gasket. I can get a socket around 5 of the hex bolts. But the 6th is behind the curve of the headers and I can't get a socket around it. It's too tight to get with a wrench. Do they make curved sockets ... or something that can help me loosen a bolt in a tight spot?
10-13-2014, 04:46 PM | #2 |
Parts and more parts
Re: Can't reach hex bolt on headers
For those, I have a ground down combination end wrench. I grind down the boxed end to make it thin,s o that I can use it, then when the bolt is loose, I use the open end to take the bolt out.
Put teflon tape on those bolts and they will turn easier, when you want them to and they will not back out, after you tighten them. It works great and once set, you will not have to retighten them on a regular basis.
Frank |
10-13-2014, 04:47 PM | #3 |
sometimes you have to heat and bend a wrenches to do what you want.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
10-13-2014, 04:52 PM | #4 | |
10-13-2014, 05:04 PM | #5 |
Charlie Daniels w/ a Tq Wrench
To add to that, if you have one local, go to HF and buy a set of wrenches for $5 or so, heat it up and bend it as needed so as to not ruin a good wrench.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
10-13-2014, 05:04 PM | #6 |
Great! Thanks, may go buy a combination wrench in that size and give it a shot.
10-13-2014, 05:05 PM | #7 |
How about a stubby open end wrench?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 10-13-2014 at 05:11 PM. |
10-13-2014, 06:00 PM | #8 |
I tried a couple of wrenches. But its on pretty tight. Ideally would have the torque of a socket.
10-13-2014, 06:14 PM | #9 |
Crowsfoot!!
Like in this link but in a standard (not metric) size. http://www.harborfreight.com/7-piece...set-94427.html |
10-13-2014, 07:01 PM | #10 |
A wrench doubled up will do the trick. Been there, done that. You could heat it and then try some penetrating liquid.
Frank |
