Old 10-13-2014, 05:23 PM   #1
yoshi
yoshi's Avatar
Brake pedal circlip
Anyone know where to get the circlip that holds the lever that go's up to the pedal?
yoshi is offline   Reply With Quote
Old 10-13-2014, 06:14 PM   #2
OrrieG
OrrieG's Avatar
Re: Brake pedal circlip
I still haven't figured out what year truck you have. Could put a pic in your avatar or add the info in your signature. I am assuming its a 47-55 because the TF do not have a circlip in the brake pedal assy. I don't have a AD assembly manual.
OrrieG is offline   Reply With Quote
Old 10-13-2014, 06:19 PM   #3
yoshi
yoshi's Avatar
Not sure how do that! It's a 49
Old 10-13-2014, 08:30 PM   #4
nvrdone
I would think any local ironmonger would have a proper clip
nvrdone is online now   Reply With Quote
Old 10-13-2014, 09:16 PM   #5
Highsider
Highsider's Avatar
I'll delete this post if you tell me you knew he lives in Great Britain.
It would probably be Whitworth measurements
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 10-13-2014, 10:10 PM   #6
nvrdone
His location says UK. If its an AD is should be a standard size clip but a metric or whitworth should be able to be tweeked to fit
Old 10-14-2014, 09:16 AM   #7
yoshi
yoshi's Avatar
Our circlips over here in the UK are too small on the outside. It fits in the groove of the shaft but allows the top hat to slide over it
Old 10-14-2014, 10:42 AM   #8
nvrdone
Yoshi: Measure the shaft diameter. Let me know that and your address. I have a bunch of clips and could mail you one.
Old 10-14-2014, 03:38 PM   #9
_Ogre
_Ogre's Avatar
and read ''how to add your truck build in your signature'' link in my signature
as should nvrdone
shop air compressor timer
Old 10-14-2014, 07:39 PM   #10
OrrieG
OrrieG's Avatar
Some body in England needs to start stocking US parts, this is like the fourth thread where someone in UK or Europe is looking for stuff I can walk down the street and buy for pennies. For the cost of shipping one clip you could get a assortment of cerclips, brake nipples, door hinge bolts, etc, etc...
Old 10-14-2014, 09:27 PM   #11
mr48chev
mr48chev's Avatar
I'd imagine that there are sources but they may not be well known outside a circle of collectors.
I went out and measured one I have.
The Clip looks like this installed
Clip retainer and spring
I measured the shaft but don't think my caliper got down in the groove right to get and accurate measurement.
Here is a link to Roto Clip which has a branch in the UK. What I suggest is downloading the catalog, figuring out which clip you need and then contact them and ask who their retailer is that is close to you. https://www.rotorclip.com/Rotor_Clip_Limited.php
My ongoing truck projects:
Old 10-14-2014, 10:00 PM   #12
Highsider
Highsider's Avatar
I have been told I am not too bright, but it looks like a flat washer and cotter pin would work better.
That clip just looks unreliable, to me.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 10-14-2014, 10:55 PM   #13
solidaxel
solidaxel's Avatar
Unreliable, I guess not, as my GMC has had one on there since, lets see.......1955.
Maybe a "E" clip or a external snap ring would hold the peddles on
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-15-2014, 11:01 AM   #14
Highsider
Highsider's Avatar
The photo was interesting, as it showed a direct comparison, of the two styles.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 10-15-2014, 02:23 PM   #15
OrrieG
OrrieG's Avatar
I'd look at a snap ring or drill for a cotter pin and washer too. Not much lateral force, mostly rotational. Somewhere there is a redneck truck running around with it just held on with bailing wire because the clip rusted out and that is what he had....
