Old 10-13-2014, 07:09 PM   #1
j.rigby15r
j.rigby15r's Avatar
ignition switch/ wires melting
Alright so I've read numerous threads and have yet to find out what I need. I've got a 64 c10 that I'm trying to hook the wires back up on the ignition switch. I install them the way I understand the wiring but my purple keeps melting. I have the purple going to the st tab, the pink to the ignition tab, red to battery, and the brown I'm not sure were it goes. Can someone help me out here by telling me or sending me picture of the back of your switch. As well as help me understand why the wire is melting. I've melted the purple wire twice. I've thought about rewiring the truck but don't have time or money.
j.rigby15r is offline   Reply With Quote
Old 10-13-2014, 07:36 PM   #2
PGSigns
PGSigns's Avatar
Re: ignition switch/ wires melting
You need to replace the purple wire all the way to the starter. It is shorted out somewhere.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-13-2014, 07:43 PM   #3
j.rigby15r
j.rigby15r's Avatar
So does that purple wire go directly to the starter?
Old 10-13-2014, 09:04 PM   #4
jtrichard
when is it melting? as so as you hook it or when you turn the key to start? Yes it goes to the starter "S" terminal
jtrichard is offline   Reply With Quote
Old 10-13-2014, 09:24 PM   #5
j.rigby15r
j.rigby15r's Avatar
As soon as I turn the key. The wire changed colors from purple to black to red. So I thought it was the wire that hooked to the battery. Does it go to the starter or where?
Old 10-13-2014, 10:21 PM   #6
jtrichard
purple should go straight to starter just turning key ON should not power that wire .. it only gets power when turned to START position take the purple off the starter solenoid and see if it will still gets hot if so then looks like you have a short if not then you have a bad solenoid or hooked up wrong
Old 10-13-2014, 10:24 PM   #7
j.rigby15r
j.rigby15r's Avatar
It was hooked up wrong. It was melted so the way from the switch to the firewall. Luckily it didn't melt any other wires.
