10-13-2014, 09:44 PM | #1 |
Not a bad nut after all..
WTB: Speedo Adapter Box w/1.300 Ratio
I'm looking for a Steward Warner speedometer adapter box similar to the one in the picture with a 1.300 ratio. The ratio is stamped on the lower pad in the picture.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
10-14-2014, 07:54 AM | #2 |
not enough hours in the day
Re: WTB: Speedo Adapter Box w/1.300 Ratio
If you don't have any luck finding a original one you can get new adapters here that look the same.
http://www.transmissioncenter.net/sp...n_______va.htm
65 K-10 Short Step 68 C-50 70 K-5 85 K-10 & piles of spare parts |
10-14-2014, 08:17 AM | #3 |
I have one not sure what ratio. I will be home Thursday I can check it if you still need one
Pulatoy |
10-14-2014, 08:44 AM | #4 |
I have a couple of them at the house. I'll try and remember to look this evening.
10-14-2014, 11:25 AM | #5 |
Second on the www.transmissioncenter.net comment from jasons. I needed to correct my speedometer on my '71 4x4 after swapping from stick sm465/np205 to a 350TH/np205 auto. Plug n play, no muss, no fuss. Look for speedometer ratio adapter. Speedometer is dead on with my Garmin GPS now.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 10-14-2014 at 11:33 AM. |
10-15-2014, 12:44 AM | #6 |
I'd appreciate it if you folks could look for any with a 1.300 ratio.
