Old 10-13-2014, 10:45 PM   #1
cameyer
64 k10 front axle swap
So i have a 64 k10 and want to make it an 8 lug. I have a 14 bolt for the rear and want to get a dana 44 or 60 up front with disk brakes my question is what will be a direct bolt in? I know the later model chevy dana 44 should bolt right in but what about a chevy dana 60? and how about the early dodge axles?
cameyer is offline   Reply With Quote
Old 10-14-2014, 12:04 AM   #2
padresag
Re: 64 k10 front axle swap
3/4 ton chev up to 87 and 91 in c/cabs and suburbans
that is what I put in mine
ron
padresag is offline   Reply With Quote
Old 10-14-2014, 12:25 AM   #3
Captainfab
60-66 Nut
A Dana 44 from '70-'79 or a 8.5" 10 bolt from '80-'91. A GM Dana 60 SRW should bolt right up as well. The Dodge Dana 60's are slightly narrower than the GM version. I don't remember if the spring perches are the same width or not. It seems like they are different? I can measure mine tomorrow. The Dodge Dana 60's have a puny yoke on them compared to a GM Dana 60
Old 10-14-2014, 12:13 PM   #4
dieseldude4bt
Dodge spring perch centers are a 1/2" wider than Chevy.
Chevy single wheel 60's are bolt in I have one in my 63.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 10-15-2014, 09:35 PM   #5
cameyer
thanks for the info guys! when doing the front swap did any of you add power steering?
Old 10-16-2014, 11:00 AM   #6
dieseldude4bt
Yes, built my own mount.
Captainfab has mount brackets avaible. I think it will will work with a 4X4.
