Old 10-14-2014, 09:02 AM   #1
70CHEVYBB
70CHEVYBB's Avatar
axles for my 70
I need 5 lug axles for my 70 1/2 ton rear end. It has 6 lug right now and I see dorman makes an axle (630-107) that is 1/16th longer. Looking by application its 87 to 88 blazer and burb and both my 70 and the 87 to 88 take the same axle bearing and it 5x5 lug pattern. Has anyone ever used this axle. I can get them for 90 each and would be a good buy if they fit?
70CHEVYBB is offline   Reply With Quote
Old 10-14-2014, 05:25 PM   #2
Kennuck
Kennuck's Avatar
Re: axles for my 70
I used 72 axles in mine, bought them off ebay for $40 I believe any from 71 - 87, 1/2 ton will work.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 10-14-2014, 06:50 PM   #3
russgoodman
russgoodman's Avatar
Re: axles for my 70
You need to measure your rear end to determine which axles you need. Measure backing plate to backing plate. The narrow rear end is 55 inches. If that is what you have, you will have to get conversion axles like Moser (I had to do this). If you have the wide rear end that measures 57.5 inches (I think) you can use the 5 lug axles off a 71 or 72 that you can pull from a junk yard or get off the parts board here.
From what I've read on here, the 70 models had a mix of wide and narrow rears. It is also possible that it has been changed/replaced over the years. Its best to measure first so you know what you are dealing with.
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554
2008 GMC Sierra Denali - 6.2L AWD - my daily
2011 Ford Flex Limited - Ecoboost AWD - wife's daily
1987 Buick Regal Turbo T - 63K miles - Strip/Street car
1965 Ford Mustang Coupe - 289, c4, 53K miles
russgoodman is offline   Reply With Quote
Old 10-14-2014, 10:25 PM   #4
70CHEVYBB
70CHEVYBB's Avatar
Re: axles for my 70
its the wide rear end. Thanks
