Old 10-14-2014, 11:38 AM   #1
Guy Dudebro
Whine from the carb
There's a high-pitched whine coming from my Edelbrock carb, especially when the engine is idling. The noise dies down a bit when I accelerate. I attached a picture. The whine seems to be coming from the part with a small gap in it (choke assembly?) that is below the carb. The black part with the old triangle shaped gasket. What is this part called and what's it function? Should I probably replace? Any help is appreciated. This board and the venerable board members are so helpful as I'm replacing all the parts on my 67 c10.
Guy Dudebro is offline   Reply With Quote
Old 10-14-2014, 12:03 PM   #2
geezer#99
geezer#99's Avatar
Re: Whine from the carb
Eddy carb needs an adaptor plate and gasket to fit on your stock intake.
Sounds like you have a vacuum leak.
Old 10-14-2014, 12:07 PM   #3
Guy Dudebro
So you think the leak is between the carb and the stock intake? Should I just remove the carb and put a new plate and gasket in?
Old 10-14-2014, 12:22 PM   #4
70CHEVYBB
70CHEVYBB's Avatar
You need a spread bore to square bore adapter. mr. gasket 1932 or edelbrock 2693
70CHEVYBB is offline   Reply With Quote
Old 10-14-2014, 03:04 PM   #5
Guy Dudebro
Will that adapter cover the bolt holes left when I remove the old part?
Old 10-14-2014, 03:27 PM   #6
geezer#99
geezer#99's Avatar
You should pull the carb off and see exactly what you have for gaskets before buying an adaptor.
Take some pics for us.
You might only need a new gasket.
Old 10-14-2014, 04:01 PM   #7
Wrenchbender Ret
It seems you have a later model manifold. First see if the gasket under the triangular plate is leaking. It is an EGR block off plate.
Wrenchbender Ret is offline   Reply With Quote
Old 10-14-2014, 04:04 PM   #8
Guy Dudebro
OK. Will pull off the carb and see what I"m dealing with. The engine is a mid-80s Chevy/Pontiac, I think. v8 350. I replaced the distributor and there was a 5 15 1986 etched into the coil, which makes me think the truck's motor was replaced around then. Thanks for the help. Will post pics with the carb off.
Old 10-14-2014, 06:01 PM   #9
Guy Dudebro
I'm not exactly a hot rod guy. I just like driving an old truck on the weekends. So would I be making a mistake to simply replace the EGR gasket and plate?
Old 10-14-2014, 06:17 PM   #10
geezer#99
geezer#99's Avatar
Go for it!
Might be the vacuum leak. Leave the carb alone for now.
Old 10-14-2014, 06:48 PM   #11
bigmac73
bigmac73's Avatar
hey Okie ,
show us some pics of your ride as well,
greetings from Bigmac73 , I grew up in Moore,Ok
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-14-2014, 09:38 PM   #12
mechanicalman
No mistake. Do that.
mechanicalman is offline   Reply With Quote
Old 10-14-2014, 09:40 PM   #13
mechanicalman
You likely have a spread-bore manifold and need the adaptor the other guys mentioned as well as a nice EGR block-off plate with new gasket.
