Old 10-14-2014, 05:31 PM   #1
no1udknow
no1udknow's Avatar
new silverado rims on our trucks?? anyone got pics??
Hey guys, I have been looking at newer silverado rims (18") for my truck, they are all over CL at fair prices and I like the way they look. I heard I would need to use spacers, but I searched and couldn't find any pics or threads. Anyone running them?
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 10-14-2014, 05:43 PM   #2
dfrank
dfrank's Avatar
Re: new silverado rims on our trucks?? anyone got pics??
IDK if they would fit. I tried putting a set of 95 chevy 6 boly wheels on my 86 and the center hole was too small.
dfrank is offline   Reply With Quote
Old 10-14-2014, 08:36 PM   #3
Mike C
Mike C's Avatar
Yup. The 6 lug wheels won't go over the pilot on an older truck, and there are no newer 5 luggers.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-14-2014, 11:19 PM   #4
no1udknow
no1udknow's Avatar
I dont see why you couldn't machine out the centers to fit.
Built not bought!
Old 10-15-2014, 07:05 AM   #5
pwdcougar
pwdcougar's Avatar
Backspacing on a 15" styled steel rim from the 70's is 4" and worked great on my 70 K10. Backspacing on a 2000 16" Chevy aluminum rim is over 5". The hub size is different too. Hub size for a 1970 is 3.5 and the late model rim is 3"
You are gonna need a heck of a spacer.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 10-15-2014, 09:12 AM   #6
no1udknow
no1udknow's Avatar
Paul
Yeah, I read a 1.5" spacer was needed for a set of 08' rims someone put on.
but, I really like the look of thee rims...
Built not bought!
Old 10-15-2014, 09:51 AM   #7
Wallee
I want to see those mounted up!
Wallee is offline   Reply With Quote
Old 10-15-2014, 10:23 AM   #8
no1udknow
no1udknow's Avatar
Me too I was thinking, I could easily machine out the centers using a cylinder boring tool.
Built not bought!
Old 10-15-2014, 01:54 PM   #9
pwdcougar
pwdcougar's Avatar
I wish someone with a machine shop would manufacture a spacer that would make the swap easier. I have a set of 97 wheels I'd love to put on my Burb when it is done.
Paul
Old 10-15-2014, 03:15 PM   #10
no1udknow
no1udknow's Avatar
Paul
I have seen spacers that use existing studs, and then have new, offset studs to space the wheels out
Built not bought!
Old 10-15-2014, 08:20 PM   #11
Mike C
Mike C's Avatar
Yes, you could machine the wheel or pay to have it done. It wasn't worth it to me for the 1991 Z71 wheels I got for $100.
I don't think the 5-6 lug adapters are piloted, that might make for an easy bolt on.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-16-2014, 10:48 AM   #12
bollybib
bollybib's Avatar
Perhaps someone could photoshop these wheels onto a truck so we can see what they might look like.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 10-16-2014, 10:50 AM   #13
no1udknow
no1udknow's Avatar
You read my mind, I put a request in the PS area this morning
Built not bought!
Old 10-16-2014, 10:54 AM   #14
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
I've been seriously thinking of running new take of 20's on my Suburban. Like to see what is found here.
bowtieguy79 is offline   Reply With Quote
Old 10-16-2014, 10:55 AM   #15
no1udknow
no1udknow's Avatar
As far as adapters go I was thinking something like this
Built not bought!
Old 10-16-2014, 02:18 PM   #16
sixSEVENcTEN
sixSEVENcTEN's Avatar
I'm running G2 Gear and Axle spacers on the rear of my 67 with 22" GM Transit wheels. The fact that the rear axle is narrower required the use of a spacer (1.5" if i remember correctly) and this also solved the hub size issue. I got mine from Summit.
No spacer required on the front. I've got the CPP Modular (narrowed track width) drop spindles and a CPP disc brake conversion up there.
Truck isn't in the nosebleed section anymore, but didn't want to let the cat out the bag yet!
Kelley
1967 C10 LWB Fleetside - Original 283, Muncie 3-Speed on Column -Porterbuilt Stage 1 Front / Stage 2 Rear Accuair E-Level iLevel - GM Transit 22s w/ '52 caps
Project Simple Green the build of Lucille - http://67-72chevytrucks.com/vboard/s...d.php?t=650871
sixSEVENcTEN is offline   Reply With Quote
Old 10-16-2014, 03:01 PM   #17
pwdcougar
pwdcougar's Avatar
That is exactly what I was thinking too with the different hub sizes machined on each side.
In college it would have been easy to machine something like this up using the lathe and mill in the machine shop.
Paul
Old 10-16-2014, 04:10 PM   #18
no1udknow
no1udknow's Avatar
Paul
you wouldn't really need the lip on the inside where the hub comes through, just grind it flush. the lug nuts "should" keep the rim centered
Built not bought!
Old 10-16-2014, 04:14 PM   #19
no1udknow
no1udknow's Avatar
well, I don't know if you saw, but SCORP hooked it up... Thanks again!
Built not bought!
Old 10-16-2014, 07:38 PM   #20
CorDog009
That looks pretty dang sharp.
CorDog009 is offline   Reply With Quote
Old 10-16-2014, 08:53 PM   #21
zipper
Those are 22s? They look like 18s for somereason
zipper is offline   Reply With Quote
