Old 10-14-2014, 06:51 PM   #1
4x4GMC
need help with frame identification
Hi I bought a 1965 gmc truck and the frame is not the original. I need to order some part so I need to know what the frame is from .
4x4GMC is offline   Reply With Quote
Old 10-14-2014, 08:17 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: need help with frame identification
Part number shows it was discontinued in 1981 Parts Book at GMPartsWiki.
Dec 13 1972 production would be for a 1973. I'm guessing here.
Old 10-14-2014, 08:50 PM   #3
RANDY COX
RANDY COX's Avatar
x'2
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 10-14-2014, 08:52 PM   #4
RANDY COX
RANDY COX's Avatar
The front frame horns are different from 65 and the front cab mounts look to be homemade to..
1964 BBC 402 4x4
Old 10-14-2014, 10:14 PM   #5
jtrichard
From what i can find from the ser#? it is 73 chevy built in flint
jtrichard is offline   Reply With Quote
Old 10-15-2014, 01:01 AM   #6
Captainfab
60-66 Nut
I agree on a '73 K10 frame and running gear.
With that newer frame, there must have been about a 3" body lift to make the body sit on the frame correctly.
Before you go any further, check the vehicle laws in AZ and make sure you won't have an issue later on with having a cab and frame with different VIN's
Old 10-15-2014, 01:34 AM   #7
padresag
we use to have that info in the faq, but I see that it has recently disappeared
ron
padresag is offline   Reply With Quote
Old 10-15-2014, 11:07 AM   #8
4x4GMC
Thank you everyone for the help
Old 10-15-2014, 06:56 PM   #9
4x4GMC
Hi every one. I have one more question is there any way to tell if it is a truck frame or blazer?
Old 10-15-2014, 07:01 PM   #10
padresag
there may be a difference in the w/base. what is your w/b?
ron
Old 10-15-2014, 07:23 PM   #11
4x4GMC
My wheel base measures 109"
Old 10-15-2014, 07:38 PM   #12
RANDY COX
RANDY COX's Avatar
Hm I'm thinking short bed truck is 115" Don't quote me on that....
1964 BBC 402 4x4
Old 10-15-2014, 08:03 PM   #13
padresag
that is a blazer chassis. 74 p/u is about 117" and what you need is 115". let's see a picture of your truck sitting on the frame. wheels will be way off centre
ron
Old 10-15-2014, 08:26 PM   #14
Mathew21
Mathew21's Avatar
Copied from here: http://www.chuckschevytruckpages.com/models.html
1973 Production Data By Model
1973 Model Body Type Total # Produced
Blazer 2wd
CC10514 C/5 106.5" WB
Open Utility
3,342
Blazer 4wd
CK10514 K/5 106.5" WB
Open Utility
44,841
Suburban
CC10906 [with rear doors]
CC10916 [with rear tailgate] C/10 129.5" WB
6,822
17,278
C/10 Conventional Cab
CC10703 Cab & Chassis
CC10704 Step Side
CC10734 Fleetside Short Bed 117.5" WB
1,922
19,408
43,987
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 10-19-2014, 07:38 PM   #15
old cool
From the looks of this thread, it appears there are a number of you who know something about frame numbers. Please help if you can.
GMC did not put vins on frames like chevy trucks in the mid 60's. So the only reference I have is the frame part number on the side of frame under each door. Can anyone tell me what year GMC frame I have (somewhere between 64 and 70). Thanks gentlemen.
Frame part number under driver's door is 2443631 2 25 77 67. under passenger door, its 2443630 2 26 77 67
FYI, GM Heritage Center and a big wig from GM Parts plant was unable to help. It would be great if someone from this forum could identify the year of my frame. Oh yea, its a swb (115 inches). Looks identical to a 64 frame in a GMC manual. It has standard drums and 8 leafs in rear.
old cool is offline   Reply With Quote
Old 10-19-2014, 07:43 PM   #16
old cool
Sorry for hijacking this thread. I just found it very interesting that some of you could actually respond to a question on frame ID. I had closed the book on my research. Great forum!
