10-15-2014, 09:58 AM | #1 |
Painting over Chrome Valve Covers???
As the title states, Can you paint over chrome valve covers? I would of course try to scuff them up. Or is this just really not a good idea. I'm not a chrome guy and had just though about putting a satin black or something coat of paint on them. Sort of as a cheap temporary fix until I find something else I prefer.
Any hints or advice in attempting to paint over the chrome would be appreciated. |
10-15-2014, 10:04 AM | #2 | |
Re: Painting over Chrome Valve Covers???
like these....
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion Last edited by no1udknow; 10-15-2014 at 10:11 AM. |
10-15-2014, 10:35 AM | #3 |
I have some edelbrock chrome valve covers, that were looking a little scuzzy. I lightly sandblasted them, and then hit them with epoxy and paint. They have been on the car for at least 15 years, and still look fine.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
10-15-2014, 11:53 AM | #4 |
If you sand blast them it will stick. I did this to an old air cleaner that had gotten slightly rusty and it worked great. I just used the shop blast cabinet.
10-15-2014, 11:59 AM | #5 |
I don't really have access to a sand blast cabinet and my little portable one doesn't really work all that well. Would something like 400 grit paper work?
10-15-2014, 12:00 PM | #6 |
Moderator
400 grit, scuff and shoot. I've done it plenty of times and it works great.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
10-15-2014, 12:56 PM | #7 |
Thanks! This is what I'm going to attempt.... should I try to use some sort of self etching primer or something before the paint? also, should I use engine paint, or doesn't it have to be?
10-15-2014, 01:11 PM | #8 |
Moderator
I would prime, and use hi-temp engine paint as well.
10-15-2014, 10:07 PM | #9 |
definitely use etch primer.I have used base/coat clear coat with no problems on valve covers and breathers.
