Old 10-15-2014, 10:49 AM   #1
dhamilton62
dhamilton62's Avatar
valve cover gaskets dry or not?
Do you guys use any RTV or other silicon for valve covers I've always thought to use rubber ones on cast covers and keep both sides dry on install, but some people say to use some RTV on the cover to gasket side only. Any thoughts or recommendations?
dhamilton62 is offline   Reply With Quote
Old 10-15-2014, 12:40 PM   #2
morethanstock66
morethanstock66's Avatar
Re: valve cover gaskets dry or not?
I've used rubber gaskets. If you are going to use RTV with it, I would only use it as a place holder for the gasket. I wouldn't use both for the full length of the mating surface. I have also used Permetex Ultra Black instead of a dry gasket. It's a pick your poison thing. Dry gaskets come off easier, but I think Ultra Black seals better. Just my .02
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 10-15-2014, 07:12 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
When I have used cork, I use a little rtv on the valve cover side.. With rubber, I don't use anything.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-15-2014, 08:33 PM   #4
62 Barnfind
62 Barnfind's Avatar
With a cork gasket you can install it dry and it will work well. I use gasket sealer instead of RTV because it fills in the imperfections and helps with the seal. I also have used copper coat. I never use RTV with gaskets.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 10-15-2014, 08:36 PM   #5
dfrank
dfrank's Avatar
I use the fel pro gaskets with the steel core and put them on dry. Never had a problem with leaking with fel pro. If it leaks put a fel pro in!
dfrank is offline   Reply With Quote
Old 10-15-2014, 08:48 PM   #6
HemiChallenger71
HemiChallenger71's Avatar
With my SBC valve covers I put indian head gasket shellac compound lightly on the valve cover side. That way the gasket sticks to the cover and stays put and I re-use them. Havent purchased a set in 5 years. I did install my 1 piece fel pro pan gasket dry except in the corners near the front and rear mains seals.
I thinly coat gaskets with black or grey RTV for water pumps and anywhere coolant comes into contact with a gasket surface. By thinly I mean you can still see the gasket and I wipe it evenly with my thumb and fore finger. Just insurance. Probably not necessary.
HemiChallenger71 is offline   Reply With Quote
Old 10-15-2014, 09:25 PM   #7
jtrichard
the best thing on water pump and "T" stat gaskets and the bolt threads is light wheel bearing or just right out of the grease gun... grease
jtrichard is offline   Reply With Quote
Old 10-15-2014, 11:27 PM   #8
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
When I Worked For GM I Used Spray Adhesive On Gasket To Sheet Metal And Let Gasket Seal To Block or Head Surface, I Had 100% CSI never Had Rechecks
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
