Old 10-15-2014, 12:50 PM   #1
no1udknow
no1udknow's Avatar
wiring harness options....
So I took the 68 out for a little road test yesterday to assess some carb adjustment/timing issues, and after driving around the block, I pulled in to the drive and popped the hood. I noticed first that I was leaking oil from the drivers side valve cover on to the headers... no biggie, then I noticed smoke lightly rising from the wiring harness running along the groove in the firewall. I quickly shut the truck off and had grabbed the harness, and sure enough, it was pretty hot. It appears to be the original harness with a few cut and pastes here and there. I'm thinking I either want to buy a new harness that has been beefed up a bit, or build my own. I am wondering who has good replacement harnesses. I am not one to toot my own horn, but I am a bit of an electrical guru, I spent many years building, testing, and repairing slot machines and I build custom bikes and their wire harnesses from scratch, so I am not scared to build a harness.... just lazy
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
