10-15-2014, 02:57 PM | #1 |
Old Engine Knocking!
so my old 250 engine started knocking time to get it out!
i need a 292 inline sadly cant find on in my area any body have a lead to where i can score one up for cheap? |
10-15-2014, 06:03 PM | #2 |
Re: Old Engine Knocking!
How about a in line 6 out of 06 trailblazer at 291hp. The earlier versions were less hp.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
10-15-2014, 06:11 PM | #3 |
A 292 isn't a direct bolt in replacement. The passenger side frame mount is different. A 292 flywheel has larger crankshaft bolts. Most 292 have a three bolt exhaust flange. You radiator might not properly cool a larger 292 engine. Unless you really need the extra pulling power I would go back with another 250engine.
10-15-2014, 06:58 PM | #4 |
10-15-2014, 06:59 PM | #5 | |
10-15-2014, 11:00 PM | #6 |
Heck yer in California...there's tons of them down there alone. The 292 has a bigger flywheel, clutch, different motor mounts, and bigger radiator.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
