10-15-2014, 04:07 PM | #1 |
K30 lift
Anyone ever lift a K30 SRW, I have a 1985 and would like to go up 2-3 inches, I am using this truck around the farmland/woods and want to put more aggressive taller tires on it. What ya know? John
10-15-2014, 04:26 PM | #2 |
Re: K30 lift
pretty much the same as a 1/2 or 3/4 ton. Steering stuff lil different. If you get rear springs over blocks, they will be 56" and heavy duty. Get a 2-3" soft ride spring, steering arm spacer, and either a shackle flip or block for the rear. Should be able to fit 35s on a narrower wheel.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
10-15-2014, 05:51 PM | #3 |
Re: K30 lift
yup, i would go blocks or flips in the rear, finding rear lift springs for a 1 ton aint easy, unless you go custom. my K30 is also a '85-good trucks!
10-16-2014, 09:06 AM | #4 |
Re: K30 lift
Like said finding 56 inch rear springs with a 2-3 lift has been hard. Just e-mailed Deaver to see if they could help. I'd even settle for 3/4 ton springs if I could find them in a 2-3 lift and 56" not a fan of blocks and my original springs are just to stiff.
10-16-2014, 11:37 AM | #5 |
Re: K30 lift
Looks like 4" is about all that's out there, including Deaver per their reply. Guess I will just have to get used to climbing up into the cab, maybe I could just get my legs stretched ;-)
10-16-2014, 11:42 AM | #6 |
Re: K30 lift
if your going 2-3" & want a better ride then with the springs you got, try some softer rated stock springs with a 2" shackle flip. be much cheaper than custom leaf packs. (although smooth ride & squarebody is an oxymoron)
i used ORD flips & got my springs from these guys, i went H-D though for hauling my camper http://www.autoandtrucksprings.com/c...ies-228-1.html |
10-17-2014, 11:17 PM | #7 |
Re: K30 lift
The Dana60 gives an inch of lift, so if you put 3" springs on front you'll need 4" rear to be equal. I used Tuff Country 4" springs on my Suburban (56"). Looking at Suspension Connection's website I don't see springs specified 52" or 56". I think if you call you'll find out better what they offer in 56". Or did you already?
10-18-2014, 08:45 AM | #8 |
Re: K30 lift
Many places don't list this stuff anymore cause of the newer trucks that are out. If you call them they prolly will have it.
10-18-2014, 09:16 AM | #9 |
Re: K30 lift
HomeSuspension Lift KitsChevrolet & GMC Suspension Kits1 Ton Chevrolet & GMC Pick-Up Suspension Kits73-91 1 Ton Chevrolet & GMC Pick-Up Suspension Kit
73-91 1 Ton Chevrolet & GMC Pick-Up Suspension Kit Front Suspension: Leaf spring/Straight axle Rear Suspension: Leaf spring/Straight axle Lug Size: 9/16 inch RH Bolt Pattern: 8x6.5 Max Stock Tire: 32x11.00 on 8 inch wheel OEM Wheel Size: 16 inch Special Notes: Real 1 Tons came with 56 inch rear springs from the factory. Some owners convert the long spring to a more common 52 inch rear spring by moving the rear spring hangers forward. The holes are usually already in the frame. These trucks came with square rear u-bolts from the factory. We run into a lot of these trucks that have been converted to round u-bolts by a previous owner. If your 1 Ton has round rear u-bolts, you will need to purchase these u-bolts separately since all of the kits contain square U-bolts. Straight axle 88-91 Crew Cabs use this kit. 88-91 3500 new body style IFS trucks use the later model kits. 1.5"-3.5" Kits 1.5"-3.5" Kits 4" Kits 4" Kits 5"-6" Kits 5"-6" Kits 8"- 12" Kits 8"- 12" Kits
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
10-19-2014, 05:59 PM | #10 |
Re: K30 lift
Ords shackle flip is either 2.5in or 4in or you could just buy 2in lift springs from them which or even go custom since they now make custom springs
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
