Door Lock Question
I am replacing the Ignition cylinder and the door locks with a keyed alike set.
This set of door only locks shows two rings that I cant locate as individual parts (I have the pawls and retainer clips). What are these called and where can I find a pair? ![]()
"Lifetime" 72 C10 Project |
![]() Join Date: Apr 2010
Re: Door Lock Question
The round rings are the gaskets if that is what you ment?
![]() Join Date: Jun 2005
Yes those are the gaskets. I have a pair. If you send me your address I will mail them to you.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
That makes sense. They looked metal so I was thinking they were a retainer ring or washer of some kind.
Stovebolt - I may take you up on that offer. I'll call in the morning and see if they are available through Classic Parts and just add them to my order if possible. I see them at LMC but cant find them on Classic Parts website.
Was able to find the gaskets this morning as part of a kit for the door handles. I went ahead and ordered them since ill need all of them eventually and the kit was less than $2.
Stovebolt- again, thanks for the offer.
Old member
I usally just make them myself.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
No problem, glad you found what you needed.
Just to update this - The lock cylinder kit came with gaskets for the door cylinders. They were not shown in the photo or listed in the description, but they were included in the package. They are not as nice as the ones I got in the gasket kit though.
