Old 10-15-2014, 09:34 PM   #1
TwinsSpeedShop
reverse light wiring
Started wiring in my LED tail lights and reverse lights. I tapped into the the light green wire at the fuse block and got nothing. Started checking and it gets power in drive instead of reverse. I came home and checked it against my wifes tahoe and the wire im using gets power in reverse as originally thought. My question for everyone is if you think that it can be the range selector.
thanks in advance
TwinsSpeedShop is offline   Reply With Quote
Old 10-15-2014, 10:40 PM   #2
ls1nova71
ls1nova71's Avatar
Re: reverse light wiring
Sounds like the range switch is out of adjustment. Loosen the two 10mm bolts and move it back a bit. if its misadjusted it could also start in gear, not what you really want.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-18-2014, 02:05 AM   #3
littlevictories
i never could get the back ups to work off the range switch. figured my JY switch was boogered up. lil turds are hard to pull without a heatgun.
littlevictories is offline   Reply With Quote
