10-15-2014, 10:31 PM | #1 |
acorn lugnut qustion ???
Tonight I went to take aw wheel off my Jeep GC and the thin metal cover over the lugnut came off in the socket. There is still a lugnut on there and I tried to get it off but it won't budge??? I even tried to over tighten the others to see if it would come off but no luck ?!?!?! I'm stumped as how to get the darn thing off. Any ideas and help will be greatly appreciated. I can't even drive it to a tire shop since I have the front all tore apart on the other side and it's all jacked up on jack stands.
Thanks in advance. RIZ |
10-16-2014, 07:13 AM | #2 |
Re: acorn lugnut qustion ???
Use the next smaller sized socket and torque that bad boy off.
You may have to use a metric socket to get a tight enough fit on the base lug nut (w/o the stainless cap). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-16-2014, 07:21 AM | #3 |
Those are disposable lug nuts. They should be replaced unless you are selling the Jeep. Can you imagine how fun those would be on the side of the road? Like Keith said, some metric socket should fit it, then chuck it.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
10-16-2014, 08:14 AM | #4 |
The socket fits if nice and tight but I just can't break it loose. I'm going to whack the socket with a hammer and try again when I get home. I worked on it for an hour instead of putting my lift in. So frustrating.
I'll give it hell today when I get home. RIZ |
10-16-2014, 08:18 AM | #5 |
Be very careful. I had them on a Grand Cherokee and broke them off but the lug nut seat stayed intact. I had to get them torched out which ruined the rims. The seat has threads in it and wont let the rim come off. Good luck. BTW it's a 19mm with the cap 18mm w/o.
10-16-2014, 10:06 AM | #6 |
Yup, the 18mm socket fits tight too........... I think part of the tin cover is still on the lug but not sure. this is what I pried out of the socket....
any tips????? RIZ |
10-16-2014, 10:13 AM | #7 |
I just did the same on my cherokee ,I went one size smaller and beat it on with a hammer and used a impact,doing it by hand didn,t have the shock it needed.
10-16-2014, 11:24 AM | #8 |
Replace them with McGard lug nuts ,they are one piece and will not rust.
10-16-2014, 11:25 AM | #9 |
Hose it with WD-40 or some other lubricant/penetrant, and add some leverage to your breaker bar via a piece of pipe.
Something's gotta give. K
10-16-2014, 05:31 PM | #10 |
i have had the same problem. best solotion i found was my 4 foot 1inch breaker bar. like was said something will move and lot of times its ez to replace the studs then wast time on the lug. time is money guys
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
10-16-2014, 05:38 PM | #11 |
OK, so.............. I got home and put a socket on the lug nut and hit it real hard with a hammer then put the impact on it and the sucker came right off...... I couldn't believe it. I guess I got lucky. I was so stressed. Thanks for all your help.
RIZ |
10-16-2014, 05:44 PM | #12 |
Use Antiseize on the studs before you put the lug nuts back on and you will not have that problem in the future.
10-16-2014, 08:17 PM | #13 |
Will not always work. I used anti sieze on threads on a 95 Dakota with the same type of lug nut. I went to take off the wheel and the hex broke off but the acorn stayed put. Then I destroyed the wheel.
10-16-2014, 10:11 PM | #14 |
That's exactly what I was talking about.I had to have them torched.
10-16-2014, 10:41 PM | #15 | |
I use a touch of grease on the studs.
10-16-2014, 11:46 PM | #16 |
18 Till I Die
Where can I buy these?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
10-17-2014, 06:42 AM | #17 |
I will be replacing mine with McGards very soon.
RIZ |
10-18-2014, 11:59 AM | #18 |
