Six in a row makes it go...
![]() Join Date: Mar 2009
C20 Energy Suspension Body Mounts - reuse parts??
I have the Energy Suspension 3-4107 Urethane Body Mount kit for my '67 C20.
http://www.energysuspensionparts.com...sion/17015.pdf The instructions say to cut-down and re-use the rear two "cab sleeves" (the bushings with the flange on top). Really? I have to use my rusty, cruddy, old bushings with all the other nice new hardware? Anybody find a good replacement for those?
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
Re: C20 Energy Suspension Body Mounts - reuse parts??
The prothane kit also doesn't provide those. Must be expensive to provide the heat treated sleeves?
1968 LWB C20 / AC / Wood Bed |
I guess. Or maybe it's an odd-ball size. I'll have to measure them up and then poke around on the McMaster-Carr site...
![]() Join Date: Dec 2012
Thread revival.
I am still in the process of replacing all of my cab bushings. I have the Energy Suspension Urethane Body Mount kit for my '70 C20 Longhorn. I have to replace the middle bolts and spacers. I measured what was left of the center spacers and came up with 2.25 x 7/8". Does that sound correct? Also the instructions say to reuse the 9/16"x6" bolts that were in the center position. I have to replace them but 6" looks too long from the measurements I took. I came up with 5". Does that sound correct? Also what is the correct front bolt size and type for the bushings? Thanks in advance for the help. ![]()
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
I was able to find 2 9'16"x5" UNC Grade 5 bolts at a nearby fastener store. Is grade 5 strong enough? I didn't want to get the wrong strength. The guy jokingly told me the minimum was 1000 pieces. Then when he looked, he had only 2 left.
ttt
#6 | |
I dunno about the bushing sizes. Too busy battling winter to work on the truck. You're out ahead of me at this point.
