Old 10-16-2014, 11:48 AM   #1
Burgie70
Burgie70's Avatar
Anti-sway bar
Got my new ECE anti-sway bar on yesterday. Wasn't too bad only had to come up with a few new cuss words! LOL
1970 C-10 350, 350 trans, ps,pb
Burgie70 is offline   Reply With Quote
Old 10-16-2014, 12:42 PM   #2
SierraMtns
SierraMtns's Avatar
Re: Anti-sway bar
Is this a beefy one? How does she handle now? Can you feel a difference? How was the install? Was it a bolt in?
SierraMtns is offline   Reply With Quote
Old 10-17-2014, 10:36 AM   #3
Burgie70
Burgie70's Avatar
Re: Anti-sway bar
It's 1 1/4 inch so it's pretty stout. I haven't really been able to test it yet although I did haul my little utility trailer behind the truck yesterday. Since I lowered the truck with new springs and shocks it rides so nice now that I'm pretty sure this anti-sway bar is going to make it even better. It installs pretty easy but it took me quite awhile to remove the two rivets in the cross member on each side. As some on the forum have indicated and now that I've done it I probably could have left the rivets and just drilled new holes in front of them because it would only move the whole bar forward a little bit. I think there's at least an inch of bar sticking out of the bushings on the lower A arm so I may have done more work than required but I was following ECE's instructions.
Old 10-17-2014, 12:37 PM   #4
no1udknow
no1udknow's Avatar
Re: Anti-sway bar
I have 85' c10 a-arms and x-member under my truck, I wonder if it is the same? I have been looking at getting a sway bar for my truck once I get it lowered.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 10-17-2014, 01:11 PM   #5
Burgie70
Burgie70's Avatar
Re: Anti-sway bar
I'm sure someone on here can answer that for you or maybe do a sway bar search on the forum.
Old 10-17-2014, 06:20 PM   #6
Fitz
Re: Anti-sway bar
Call Stan at Early Classics and ask him.
Fitz is offline   Reply With Quote
Old 10-17-2014, 08:10 PM   #7
Average Joe
Average Joe's Avatar
Re: Anti-sway bar
Should fit. I used a 1 1/8" front sway bar off a '86 Suburban on my '67. It bolted right up after removing the aforementioned rivots. Made a HUGE difference btw.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 10-17-2014, 11:20 PM   #8
michael bustamante
michael bustamante's Avatar
Re: Anti-sway bar
Yup itll work
1967custom
michael bustamante is offline   Reply With Quote
Old 10-18-2014, 03:35 AM   #9
Turbo1dr
Turbo1dr's Avatar
Re: Anti-sway bar
Back in 1988, I installed a front and a rear anti-sway bar on my truck. I just used bars off of the front of a full sized 70's GM car. The mounts fit perfect between the rear frame rails. They also fit perfect on the front too. Here is a picture of the rear bar.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored
1978 Turbo Malibu - Owned since 1986
1987 Grand National Aerocoupe -1 of 1
1988 LeSabre T-Type - Supercharged
Turbo1dr is offline   Reply With Quote
Old 10-18-2014, 08:14 AM   #10
Lees68GMC
Lees68GMC's Avatar
Re: Anti-sway bar
Here's my front, after market bar, a buddy just got the same bar for $99.00 complete
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
