Old 08-14-2003, 08:44 PM   #1
72c10step
WHYBYNU when old will do?
72c10step's Avatar
Oil canister to filter conversion
My friend wants to convert his oil canister to an oil filter. He thinks he can just buy the filter and throw it on, and I could have sworn that you need a conversion kit. Which is it, and if he needs a conversion kit, what is it, and where can he get it?
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 08-14-2003, 09:19 PM   #2
BIG ORANGE
BIG ORANGE's Avatar
Is it far a small block or a Big block? Transdap makes a great conversion for this and I use it for my 67 BB I built acouple yrs back,dont waste you money or time with the Mr Gasket type it's junk and want work!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-14-2003, 09:38 PM   #3
Sammy
If it's a sm block 307 any good part store should have a conversion kit required for the canister to spin-on filter.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-15-2003, 08:44 AM   #4
72c10step
72c10step's Avatar
His truck has a 283 small block in it.
-1984 Jeep CJ7
-2003 Honda 300ex
Old 08-22-2003, 09:19 AM   #5
72c10step
72c10step's Avatar
ttt
-1984 Jeep CJ7
-2003 Honda 300ex
Old 08-22-2003, 09:49 AM   #6
dubie
dubie's Avatar
Yeah you need to buy a good conversion kit to amke it work. It only takes about 5 minutes to change it over. I will be doing the same thing on the wifes 283. It came out of a 57 Chevy Bel Air
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 08-22-2003, 10:07 AM   #7
VTKidder
Got the adapter kit for my 350 at NAPA the same time I got a filter; as said above, 5 mins. $12.49 for the kit.
VTKidder is offline   Reply With Quote
Old 08-22-2003, 10:56 AM   #8
72c10step
72c10step's Avatar
Thanks guys!
-1984 Jeep CJ7
-2003 Honda 300ex
Old 08-22-2003, 03:57 PM   #9
jimfulco
Does it replace the stock adapter or do you use both? I've heard both ways, but I don't know for sure.
jimfulco is offline   Reply With Quote
Old 08-22-2003, 03:57 PM   #10
jimfulco
dp
Old 08-22-2003, 04:06 PM   #11
Maximum Overdrive
December 21, 2012
Got mine at NAPA and it went in pretty quick. I did like the cansiter type but it is just so much easier and quicker to change the oil and filter with a regular filter.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 08-22-2003, 05:01 PM   #12
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Two of my cars have the cannister and I like them. The only trouble is that I have to go to the GM dealer to buy them filters anymore.
They are a bigger filter so maybe better? I don't know.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-25-2003, 06:17 AM   #13
VTKidder
I don't remember exactly what came off and what went on when I did the swap (1997). I believe all you did was take off the canister, add this adapter and screw your new filter to it.
