Old 10-16-2014, 06:28 PM   #1
Jake Wade
Jake Wade's Avatar
Wheel caster
Does anyone know how to adjust wheel caster on a '85 C10 2WD? What is the stock spec? My truck feel like it needs more .
Jake Wade is offline   Reply With Quote
Old 10-16-2014, 06:37 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Wheel caster
With shims.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 10-16-2014, 06:49 PM   #3
tinydb84
tinydb84's Avatar
Re: Wheel caster
Originally Posted by Just call me Sean View Post
With shims.
Your thinking of camber.
Caster cant really be adjusted with our trucks. They make adjustable ball joints I believe though. There are a few threads on here how to modify the arms to move the ball joint (or arm forward).
David
Instagram: myfabguy
Old 10-16-2014, 06:56 PM   #4
J Knight
J Knight's Avatar
Re: Wheel caster
Which one of these adjustments do you think you need to make?
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 10-16-2014, 07:37 PM   #5
Just call me Sean
Re: Wheel caster
No, I know what caster is. Putting shims on one bolt of the control arm will affect caster.
Old 10-16-2014, 07:40 PM   #6
tinydb84
tinydb84's Avatar
Re: Wheel caster
You are correct but with our trucks you wont be able to get enough without throwing out some other aspect of the alignment.
Here is a good thread: http://67-72chevytrucks.com/vboard/s...d.php?t=501241
Or look at Rob from No Limit's JT build.
David
Instagram: myfabguy
Old 10-16-2014, 08:22 PM   #7
Jake Wade
Jake Wade's Avatar
Re: Wheel caster
Caster
Old 10-16-2014, 08:27 PM   #8
Just call me Sean
Re: Wheel caster
That's why alignment shops make the big bucks. Mess with one thing it affects another, that's what the machine is for.
But, I did answer his question. That's how it's done.
Old 10-16-2014, 08:30 PM   #9
J Knight
J Knight's Avatar
Re: Wheel caster
Caster
What is you truck doing? Pulling to one side?
John
Old 10-16-2014, 09:29 PM   #10
clinebarger
Re: Wheel caster
My Suburban loves a lot of Positive Caster, Mine is set about 5 degrees, That is max while keeping Camber in check on my truck.
I Believe 3/4 tons have more adjustment because of the ride height.
The negative is the tires will talk to you on "Full Lock" turns.
The factory specs don't mean jack, Keep Camber around 0 degrees, Get all the Caster you can, Then set the Toe-In 1/8" to 1/4" total Toe-in works great.
Not many shops will deviate from Specs, They believe their fancy machine & Specs will make your truck drive good, Find an old front end shop with a "Lite-A-Line" & a In-Ground Scrub Meter for Toe-In.
clinebarger is offline   Reply With Quote
Old 10-16-2014, 10:02 PM   #11
Jake Wade
Jake Wade's Avatar
Re: Wheel caster
It does not pull, there just is not any road feel and steering wheel does not want to return to center when letting go from a sharp turn.
Old 10-16-2014, 10:33 PM   #12
Just call me Sean
Re: Wheel caster
Did someone adjust the steering box too tight?
