Old 10-16-2014, 09:22 PM   #1
paulbrgr9999
another disk swap problem
Last night we tried to connect the rear brake line to the proportioning valve. The line is the wrong size. Do I have to replace the entire line coming from the rear? If so can I find it pre bent? Or will I have to custom make a line?
thanks ahead of time
thanks
paulbrgr9999 is offline   Reply With Quote
Old 10-16-2014, 09:56 PM   #2
Xeen
Xeen's Avatar
Re: another disk swap problem
To answer your question we need a lot more information first, we need to know what parts you are using all the way from the brake booster to the rear brake set up.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-16-2014, 10:06 PM   #3
paulbrgr9999
1970 c20 with drum brakes all the way around. 1972 c20 doner front end rebuilt and put on the 1970. So drum still on the back but 72 c20 front end on the front. Frankenbrakes!
Old 10-16-2014, 10:33 PM   #4
Xeen
Xeen's Avatar
If you used the 1972 brake booster and prop valve you need to order a 1971 front to rear brake line from www.inlinetube.com and you will be all set.
I would call Inline tube and tell them you need the 1971 rear brake line starting at the prop valve and ending at the rear suspension crossmember.
Old 10-16-2014, 11:02 PM   #5
paulbrgr9999
Ok, thank you. Thats progress. But what I need is the 72 right? Because its now a 72 front end. Everything, booster, prop valve, master, ball joints, tie rods, etc.
Old 10-16-2014, 11:04 PM   #6
davepl
davepl's Avatar
Lines are reversed on a 72 3/4 disc vs a 70 3/4 drum. Front port is rear wheels, rear port is front wheels. You need the right prop valve (not cheap) and master and all of that...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-16-2014, 11:08 PM   #7
paulbrgr9999
Yea, I know about all that. I just want the rear brake line to connect to the prop. valve. Sounds like I need to buy a new line or custom make my own.
Old 10-16-2014, 11:10 PM   #8
davepl
davepl's Avatar
If you can buy one, you're doing better than me. Well, actually I did buy them, they just were completely wrong for a 3/4 ton even though listed as such. I think you'll be making your own.
Old 10-16-2014, 11:13 PM   #9
Xeen
Xeen's Avatar
The reason you need a 1971 brake line is because you have a 1970 frame which is compatible with the 1967-71 brake line but not the 1972 brake line.
The 1972 brake line is routed completely different and connects to the intermediate rear crossmember instead of the suspension crossmember like it is from 1967-71.
Old 10-16-2014, 11:16 PM   #10
paulbrgr9999
I think I read your post about how unhappy you were with the first company you bought from. Classic tube is better right?
Old 10-16-2014, 11:19 PM   #11
paulbrgr9999
This is giving me a terrible head ache!
Old 10-16-2014, 11:22 PM   #12
Xeen
Xeen's Avatar
Trust the Xeen I won't steer you wrong!
If Inline tube doesn't carry the part just buy it from some place else.
Old 10-16-2014, 11:36 PM   #13
69chevytrucker
69chevytrucker's Avatar
bush it up put the right size bushing in the valve screw in the brake line
69chevytrucker is offline   Reply With Quote
Old 10-16-2014, 11:54 PM   #14
mgchevyparts
mgchevyparts's Avatar
Just buy an adaptor. You need to know the thread size for each and get the correct adaptor.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 10-17-2014, 07:09 AM   #15
Andy4639
Old member
Andy4639's Avatar
Wink Re: another disk swap problem
Correct just buy the adapters. I just had to do this on my 71. The chrome master cylinder was all metric.
Here is the link.
http://67-72chevytrucks.com/vboard/s....php?p=6858300
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
