Old 10-16-2014, 10:26 PM   #1
1774btcrew
1774btcrew's Avatar
Posi unit out of a dana 44 worth picking up?
I spend the biggest part of my time in the 73-87 section and am not real familiar with the 60-66 trucks. I am always watching for posi units and found one today under the rear of 65 Chevy with leaf springs. It has 3.54 gears. I would also like to know if it will fit in front Dana 44's. Any help would be appreciated. I have a customer looking for one for the front of his Blazer.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 10-16-2014, 11:58 PM   #2
Captainfab
60-66 Nut
Re: Posi unit out of a dana 44 worth picking up?
As far as I know it should fit a front Dana 44. I don't remember where the carrier breaks are on the Dana 44. So it may or may not work with his gears.
Old 10-17-2014, 12:06 AM   #3
1774btcrew
1774btcrew's Avatar
Thanks for the info. He actually has really high gears at 2.73
Old 10-17-2014, 06:19 AM   #4
dodgiesdad
dodgiesdad's Avatar
In my 65 K-10 with a mid 70's Danna 44 front I am running a limited slip I originally took out of the rear of a late 90's Wrangler, then I had it in a 99 Ram 1500 until I upgraded it to a locker and lower gears. I am now running thick cut 4.11's on it. The carrier break is 3.73 and under and 3.91 and over. I did and would suggest rebuilding the carrier before you use it.
dodgiesdad is offline   Reply With Quote
Old 10-17-2014, 03:03 PM   #5
1774btcrew
1774btcrew's Avatar
Thanks for the info everyone! That is exactly what I needed!
