Old 10-17-2014, 02:33 PM   #1
70ptta
axle swap info
hey guys got a quick question. I have 2 72 cheyenne swb 4x4 trucks. i want to know if swapping the axles would be easy. one truck has a 8 lug corp 14 bolt and dana 44 front it used to be an auto truck now has a 4 speed with granny low and the other truck has a 12 bolt and a 6 lug dana 44 with a th350. would this be a direct bolt on swap? thanks
70ptta is offline   Reply With Quote
Old 10-17-2014, 03:21 PM   #2
DWilbur
Re: axle swap info
Not a problem to do your swap. keep the U bolts with the axel they came from on the rear axels. front will be a direct swap. check the break lines they could be different.
DWilbur is offline   Reply With Quote
Old 10-22-2014, 05:38 PM   #3
WhiteWhale
WhiteWhale's Avatar
Re: axle swap info
where are you sourcing bearings to rebuild the HO52?
WhiteWhale is offline   Reply With Quote
Old 11-01-2015, 06:13 PM   #4
70ptta
Re: axle swap info
what about the drive shafts? will the still work?(shafts and length)
