Old 10-17-2014, 09:02 PM   #1
brian1971
brian1971's Avatar
20x9.5 rear tire backspacing on 71-72
I am going to be running 20x9.5 rear tires on my 71 short fleetside,Was wondering what backspace you guys are running on the wider rear 71-72 models.If possible can you post pics thanks Brian.
In front I'm going with 20x8 so should I use 5 or 4.5 backspace.
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 10-18-2014, 03:13 AM   #2
Fitz
Re: 20x9.5 rear tire backspacing on 71-72
Why ask a total stranger, someone that might not be able to find their backside with a flashlight and a map when you can go out to your truck and measure it?
Fitz is offline   Reply With Quote
Old 10-18-2014, 06:27 AM   #3
brian1971
brian1971's Avatar
If I could measure right now I would body is at paint shop and frame is at my house just trying to see what guys on here are running and some pics.Isn't why this forum was started so 67to 72 truck owners help each other out.
Brian
Old 10-18-2014, 05:53 PM   #4
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
Pm lowlife99
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 10-18-2014, 06:56 PM   #5
jmking9
jmking9's Avatar
My truck is a 70, but has the wide rear end like the 71's and 72's. My front wheels are 20x8 with 4.5" of backspacing. (255/40 tire) No rubbing.
The rears are 20x9.5 with 5.875" of backspacing. (295/40 tires) They fit without spacers, but were very close to rubbing the inner fenders. I run a 1/4" spacer to set them out just a bit. I think 5.5" BS would work perfectly. Here's a couple pics that will give you an idea how mine fit.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 10-18-2014, 11:46 PM   #6
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
5.0'' Backspacing would be just about right. I install alot of 20X10.0's with 5.50'' backspacing. Half inch narrower rim , half inch less backspace. I also install alot of 285/40/20's and 295/40/20's
ksbrktracer is offline   Reply With Quote
Old 10-19-2014, 01:10 AM   #7
brian1971
brian1971's Avatar
Thanks JMking ,Tommy for pics and info on backspacing with tire sizes.
I really like the look of the 295/40/20 on the back.
Brian
