Old 10-17-2014, 09:57 PM   #1
In The Ten Ring
I'd really like to see pics of 'burbs and panels hauling.
I really want a panel or a burb but it can't be a toy for me, it has to work. May I see your pics of yours working for you?
In The Ten Ring is offline   Reply With Quote
Old 10-17-2014, 10:34 PM   #2
72MARIO
72MARIO's Avatar
Re: I'd really like to see pics of 'burbs and panels hauling.
Camper hauling
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-18-2014, 11:42 PM   #3
64Bezer
Boat hauling
Rob
64Bezer is offline   Reply With Quote
Old 10-20-2014, 01:51 PM   #4
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
Hauled some fence material couple weekends ago.
bowtieguy79 is offline   Reply With Quote
Old 10-27-2014, 09:14 PM   #5
Sluggie
http:// [/IMG]
Sluggie is offline   Reply With Quote
Old 10-27-2014, 10:33 PM   #6
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Well, I guess I can toss up a pic of my burb hauling. And for the record, the 63 was only on the trailer because I moved from SD to ND and I can only drive one at a time.
It had also hauled a few fullsize trucks to part out, and a few project cars I bought that didn't run, and a small bobcat a time or two.
I should have taken a pic last week with the Burb's interior loaded with 10 4"x4"x10', 30 2x4x8' with a couple 2x6x12's resting on the dashboard to let the back doors shut.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 10-28-2014, 12:59 PM   #7
taylorbg
lowrollin70gmc....
What is in your set up? Engine, gears, tranny, and tire size? How does it work for your towing needs? I am trying to build mine up as a towing rig, but currently it is a dog. I have 350/350 with 33 ties and 3.73 gears.
taylorbg is offline   Reply With Quote
Old 10-28-2014, 11:51 PM   #8
lowrollin70gmc
Too many projects
I'm a little bit of a cheater, I run a 12 valve Cummins turbo diesel turned up a little bit backed by an nv5600 6 speed transmission, NP205 transfer case, and 3.73s turning 35" tires (I've also ran 37s on this setup). There is a link to my build thread in my signature: "The Dakota Cadillac".
It works awesome towing, I can drive a loaded trailer at 75-80mph with power to spare. I do typically slow it down to 70 to save on fuel. Empty I've averaged just under 20mpg and loaded it's given me 15/16mpg. I love the truck but it was a lot of work to put together and is still a work in progress, but it's driven great in the 2 1/2 years since I did the conversion.
I've also owned an 88 350 powered 3/4 ton truck (700R4, 4:10s, & 31s), pulled the same loads, and it isn't a comparison to the diesel. But driving at a reasonable speed it always got the job done, just not as quickly.
Andrew
Old 10-29-2014, 11:06 PM   #9
Alex V.
Alex V.'s Avatar
Here's my '67 2WD 1/2 ton, 350/4-speed (factory 327), w/HD cooling, alternator, springs, and shocks, towing my '90 Comanche to its new owner a few months ago. Don't let the "10" on the side fool you, she'll pull.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 10-29-2014, 11:44 PM   #10
64Bezer
My 72 above (pulling the yellow boat) has a HT383/700R4 and 4.10 gears. I tows quite well with this combo, but I'd like air springs in the rear. I find they're a bit soft for towing. It doesn't tow poorly because of them, it just sags. Especially considering that the tongue weight of that boat trailer is only about 200 lbs.
Old 10-29-2014, 11:52 PM   #11
taylorbg
Here's mine. My boat is heavy, but it doesn't sag at all. It doesn't like hills though and wobbles when I get over 55. If I can get the wobble issue figured out, I'm thinking about doing a 383 if I can afford it and convince the old lady that that is better than new carpet.
Old 10-29-2014, 11:56 PM   #12
64Bezer
Taylorbg,
I put CPP sway bars front and rear and it made a HUGE difference. Rear especially. Used to wallow like a pig going down the highway. Not any more. I really recommend a rear sway bar on a burb. They are so much more top heavy in the rear compared to pickups.
Rob
Old 10-30-2014, 01:11 PM   #13
taylorbg
Sway bars are next on my list. Fixing to redo the front end. Ball joints, tie rod ends, etc. Did you install the sway bars yourself? If so, how difficult was that. It is killing me to keep having to pay people to do the work for me. I just don't have the free time these days. Also, is your four wheel drive? Mine is, wonder if those work for both two wheel and four wheel.
The 4x4 sections say to get them off later trucks to save money, but then you have to fab things up to get it to work. I prefer bolt on and be done.
Old 10-30-2014, 07:22 PM   #14
64Bezer
Mine is a 2wd with coil springs in the rear. I put the sway bars in myself. In concept it's just drilling a few holes and bolting it up. The trick is that the rear control arms are basically 2 c-channels welded together. The sway bar brackets are supposed to get a bolt into each c-channel. It's a squeeze getting the brackets mounted without them being a bit twisted a bit. I think CPP could do a much better job if they fabbed up a better (more custom, less generic) sway bar bracket for the control arms.
