Old 10-17-2014, 11:11 PM   #1
AZ59apacheguy
Megatronix Hood Lock install for Task Force trucks
Hi. I just bought one of these Megatronix HL6 mechanical hood lock cable security systems with ignition interrupt. I'm going to install it in my '59 3100 Task Force. Has anyone installed one of these in their 55-59 Task Force trucks? I have seen some picks of these installed on later Chevy's, but those have a different style hood assembly. Any picks or advice would be greatly appreciated. Thanks for your time
AZ59apacheguy is offline   Reply With Quote
Old 10-18-2014, 06:18 PM   #2
_Ogre
_Ogre's Avatar
Re: Megatronix Hood Lock install for Task Force trucks
you must live on the wrong side of the golf cart track
shop air compressor timer
Old 10-18-2014, 06:43 PM   #3
AZ59apacheguy
Ha ha, very funny. It's not what side of the golf cart track your on, were surrounded by them
Old 10-18-2014, 08:59 PM   #4
OrrieG
OrrieG's Avatar
Good insurance works for me. In the old days when I lived in sketchy neighborhoods old school padlock and heavy chain was the deterent. Big noisy dog helps too. I never had much luck with aftermarket electronic alarms, to many false alarms. Leaving a couple of .45 or 9mm cartridges in plain site on the console or dash seems to help too.
OrrieG is offline   Reply With Quote
Old 10-22-2014, 09:36 PM   #5
tinyjaime
I wrote the company because i have a 1956 chevy 3100. Here is their reply.
We'd recommend the HL7 (7 footer) for your vehicle as the hood is quite long on these older GM trucks. Below is the link to the installation manual:
http://megatronixusa.com/manuals/HLManual.pdf
Best Regards,
Sales Dept
Megatronix
TEL: 818-886-8888
FAX: 818-886-8889
EMAIL: sales@megatronixusa.com
WEB: www.megatronixusa.com
tinyjaime is offline   Reply With Quote
Old 10-22-2014, 10:32 PM   #6
58CameoAZ
AZ59apacheguy I live an Hour up the hill from you and i tell people i live in the PROJECTS
of Payson.Lol..
Good Luck with the Install & maybe we will cross paths someday!
Allen
58CameoAZ is offline   Reply With Quote
Old 10-22-2014, 10:44 PM   #7
AZ59apacheguy
Best Regards,
Sales Dept
Megatronix
TEL: 818-886-8888
FAX: 818-886-8889
Hi. Thanks for the replay and info. I got my Megatronix unit in the mail today. Before ordering, I measured out the length along the left side of the engine compartment to the hood release; it came out to just under 6' ( 5' 5" ). I ordered the 6' foot one. I took the Megatronix unit out to the truck tonight and did the best I could to mock it up. I'm glad I bought the 6' one, the 7' would have been WAY too long. I'm going to do a step by step thread on this install. I am also going to somehow incorporate this unit to lock the hood release and NOT hang a bracket from the hood itself ( to me that would look too tacky ). I hope to start this weekend.
Old 10-22-2014, 11:51 PM   #8
tinyjaime
Great I want to do one also and a nice install step by step thread would be cool. Take lots of pics and I would be interested in to see how hidden and how it looks.
Good luck
Old 12-26-2014, 10:09 PM   #9
AZ59apacheguy
So it's been some time since this post and I have finally finished the mock up of this install. I did not want to have the locking mechanism on top of the Hood Latch Panel for everyone to see, rather I wanted it somewhat hidden.
I did have to shorten both the mounting bracket and sliding post responsible locking the hood latch. As you can see I mounted the locking assembly underneath and coming from the back of the Hood Latch Panel.
I then drilled completely through the entire Hood Latch Assembly to make sure the sliding post went through not only the Hood Latch but the main body of the Hood Latch Assembly itself.
Since I came up from behind the Hood Latch Panel, there was too extreme of an angle run the cable in front of the radiator ( it kept binding ), so I had to run it up over the radiator a bit. Not my first choice, but it still beats mounting the whole locking assembly on top of the Hood Latch Panel.
I then ran the cable along the Drivers side inner fender and then through the firewall.
The main body of the Megatronix Locking Mech was then attached to the underside of my steering wheel. I would like to come up with something better than the screw clamps, but for now they work just fine.
Old 12-26-2014, 11:16 PM   #10
Highsider
Highsider's Avatar
To lock, you push in the key, then turn the key and it is locked?
Is the tumbler spring-loaded, so it pops out to release the hood, when you unlock the key?
Thanks!
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 12-26-2014, 11:35 PM   #11
AZ59apacheguy
Hello Highsider. Yes, the tumbler is spring loaded. The only way to remove the key is to turn it to the lock position, then you push in the tumbler to lock everything. When you want to unlock the hood, insert the key turn to the unlock position and the tumbler releases out ( the key stays locked in the tumbler ). This Megatronix unit also has a starter kill feature you can wire into your ignition system, when it is in the locked position, the starter kill is engaged and vehicle can't be started.
Old 12-27-2014, 02:00 AM   #12
Dan in Pasadena
Dan in Pasadena's Avatar
Seems like too damn much hassle to me. Not to mention probably more expensive than THIS simple hood lock solution I saw at a show a few years ago. These are ordinary desk locks you can buy at Home Cheapo:
I think when I get around to doing this I will use an RV or barrel style lock like this. Just a bit more of a hassle for a thief and maybe it'll make them move on to the next car. In my opinion, any of these are only deterrents. If a thief wants what you have bad enough they'll keep at it til they've got it....unless you make it a pain in the butt for them.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 12-27-2014, 02:12 AM   #13
AZ59apacheguy
That IS a good idea Dan In Pasadena, thanks for sharing. You are correct, if the thieves REALLY want your vehicle, they will eventually get it. My Megatronix unit is only one of many deterrence on my truck. The thieves will have to work pretty hard to get my ride, and the longer it takes to a thief the more likely they'll give up. Thanks for sharing
Old 12-27-2014, 10:47 AM   #14
Highsider
Highsider's Avatar
I don't think I could bring myself to drill a hole in my hood or fender, to install a lock.
I like apacheguy's cable with ignition lockout, too.
Or just drive a panel...nobody steals them!
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 12-27-2014, 07:04 PM   #15
Dan in Pasadena
I could and will do it but I think you have to do it before all the primer and paint work to make sure the hole in the hood and body work is well sealed. I'd also put a small polished stainless plate where the tab goes into the bodywork to avoid future scrapes and scratches.
