Old 10-18-2014, 09:12 PM   #1
scrappy's 69
TH350 Trans Leak
I know this has been asked before, but I haven't been able to find the thread. My TH350 is leaking around the speedo cable, what can be causing this and what do I need to fix it? Thanks for any help.
“Somebody has to do something, and it's just incredibly pathetic that it has to be us.”
Jerry Garcia
scrappy's 69 is offline   Reply With Quote
Old 10-18-2014, 10:54 PM   #2
dmack91
dmack91's Avatar
Re: TH350 Trans Leak
Should be an O-ring on the speedo gear portion that goes into the trans.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 10-19-2014, 01:50 AM   #3
mechanicalman
Get one of these
http://www.ebay.com/itm/GM-TH350-Tur...7503bc&vxp=mtr
And then if you need a new speedo gear (seal groove worn into the shaft or worn shaft) count the gear teeth and note the color of the gear and get a new gear: scroll down this page a pick out a new one, not used.
http://www.ebay.com/sch/i.html?_odkw...r&_sacat=33726
mechanicalman is offline   Reply With Quote
Old 10-19-2014, 10:07 AM   #4
Lee H
Lee H's Avatar
A new bullet will likely solve your problem. Be sure the lip seal is seated. The last few I've gotten the seal was only pressed in a little and it leaked worse than the old. You can get these bullets at your local auto parts house. You can also get the the lip seal and o-ring if you have a local trans parts house and replace them your self. If your speedo if off nows a good time to get the correct speedo drive gear.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-19-2014, 08:02 PM   #5
scrappy's 69
Thanks for the info!
Jerry Garcia
Old 10-19-2014, 08:33 PM   #6
davepl
davepl's Avatar
I don't know about the TH350, but some transmissions (like the TKO-600 as an example) have both an inner and outer o-ring and if you forget either, it'll leak.
I'm sure someone will chime in here if, in fact, there are two on an old hydramatic.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
