Old 08-14-2003, 11:30 PM   #1
SCOTI
SCOTI's Avatar
Replacing window regulators
I've got to replace the driver side non/pwr. window regulator on my 74. Any tips or tricks to make the job easier??
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-15-2003, 12:40 AM   #2
Russell
Professional Grade
Russell's Avatar
Thats the little switch right?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-15-2003, 11:23 AM   #3
SCOTI
SCOTI's Avatar
Nope. Non-power windows. The regulator looks like it's held in place w/4 bolts. I'm just trying to figure out any tricks to get the regulator out & make everything go easier upon re-assembly.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-15-2003, 11:33 AM   #4
MattA
MattA's Avatar
Scot, it is really not that difficult. You will want to tape the glass to the top of the window frame to keep it from falling. Once the regulator is loose just slide the guide rollers to the end of the guide to remove. Make sure you go ahead and lube the guides when the new one goes back in. Silicone spray works good in the felt run channels to make the glass go up easier also. You shouldn't have any problems.
matt
MattA is offline   Reply With Quote
Old 08-16-2003, 09:12 PM   #5
SCOTI
SCOTI's Avatar
Matt, have you done this vintage before? I was going to ask you but figured you had worked on the newer stuff.... nothing this old.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-18-2003, 01:34 PM   #6
MattA
MattA's Avatar
It shouldn't be too much different. I can't imagine you getting in there and not being able to figure it out. Feel free to call or bring it by if you want.
matt
Old 08-18-2003, 04:48 PM   #7
Jonboy
Slots go on anything!
Scot,
you can practice on yours and then come by and put my doors together
1974 Jimmy- 5.3/4L80e/NP241
Old 08-18-2003, 07:35 PM   #8
SCOTI
SCOTI's Avatar
Man.... I called the chevyhouse today, they get $100+tax for the regulator & I have to go down there & pay up front first. I guess that's better than the internet @ around $125 for genuine GM or $35 for aftermarket stuff.
My problem is.... I would want to replace them as a pair, you know, so they both work equally. I know, I'm a dork.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-18-2003, 11:03 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally posted by SCOTI
..... I would want to replace them as a pair, you know, so they both work equally. I know, I'm a dork.
Yeah, we know you are a dork, but that's another issue :p
I say go with the GM units regardless. I ordered some more stuff from LMC, and got the same mix of good and bad. The windshield washer bottle was made in Tiawan, but it looks pretty close to OEM. The stickers I ordered are official GM restoration parts, but they aren't the right ones. They are close, but not correct.
I say go with GM stuff. It cost more, and may not be perfect either, but it's better than the crap shoot you take when ordering from LMC...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
