![]() Join Date: Oct 2013
LY6 Transmission has a Leak
My 1986, C10, SB, with the LY6 transmission is leaking trans fluid, I think around the speedometer cable outlet. Need to clean and dry it all up to confirm. If so can you replace the seal from the outside? Easy or hard? Who sells the seal too?
That what I get for cleaning all the year junk off it. Les |
Re: LY6 Transmission has a Leak
Clean the area around speedo cable today, will see what it looks like tomorrow. The connection of the speedo cable to the trans is a little different for this trans.
Les |
All the speedometer seals can be changed from outside the transmission.
