Old 10-19-2014, 02:41 PM   #1
Ricks1971
Ricks1971's Avatar
rear window rubber molding
Hey guys who make the best rear window rubber gasket or molding? My back window has the ss trim. thanks Rick
Ricks1971 is offline   Reply With Quote
Old 10-19-2014, 04:14 PM   #2
kcsa75
kcsa75's Avatar
Re: rear window rubber molding
You want the Precision brand. Contact GMCPaul or Classic Heartbeat. Both support the forum.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 10-19-2014, 07:04 PM   #3
Sammy
Really I try to use Precision from one of ours board vendors even if they are just above some of the others price wise. However in the past I have used LMC rubber with about 90% satisfaction. One clearly marked 67-72 on the rubber n on the package label in a box. Only to find out after sitting on my shelf for two years it was 2 1/2 inches too big. Too much time had passed to make a stink. But a later purchased LMC non-trim type fit great. Both seals were not my actual purchase but got them thru a third party.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 10-19-2014, 07:30 PM   #4
zicc1835
zicc1835's Avatar
i jus bought a prescion ss trim rear window gasket from Tom tkorinek the installer had no issue with it was a slider on a 72... what i did find out is the new gaskets don't fit on the old windshields which are thicker than the repop windshields
zicc1835 is offline   Reply With Quote
Old 10-20-2014, 01:10 PM   #5
Classic Bowties
Always on the hunt...
Hi Rick, if this is for your 67 then your truck must have the optional A10 panoramic cab. If it were my truck, precision part #WCR 1092 T is the way to go and if needed I have it on hand ready to ship. I should be getting your tilt all buttoned up this afternoon, the column and color change came out looking sweet! Do you want to see a few pics, or would you rather save the #514 color suspense a surprise till opening up the box? Mel
Classic Bowties is offline   Reply With Quote
Old 10-23-2014, 11:40 PM   #6
Classic Bowties
Well... this am the puter said that your freshly rebuilt tilt column and new dlx rubber was on the truck and out for delivery. Are we happy with the final results, what do you think about your choice in color? Mel
