10-19-2014, 08:43 PM | #1 |
2wheel drive blazer
What would be my best route to make a 2wheel drive blazer?
-chop up a suburban frame? -chop a lwb truck frame? -or can a 4x4 be converted? Thanks in advance for the advise!
1986 Chevy Silverado LWB (project) 1967 Chevy SBSS (future project) 2003 Chevy Tahoe (wifes daily) 2004 GMC 2500 Duramax (company truck) 1986 GMC Wrangler LWB (newly acquired beater) |
10-19-2014, 08:47 PM | #2 |
Re: 2wheel drive blazer
10-19-2014, 08:57 PM | #3 | |
10-27-2014, 10:46 AM | #4 |
I always Thought that a 4x4 frame had different rails than 2x4 and was a pain to convert?
10-27-2014, 01:29 PM | #5 |
People convert 2wd - 4wd all the time. I imagine it wouldn't be that hard to convert 4wd - 2wd. I'd go the junkyard and find a good donor front suspension and take lots of pictures of the connecting points and compare to your 4wd front end.
You may need a new transmission or at least a bolt on output shaft to eliminate the transfer case. On my 59 when I converted 2wd - 4wd I needed a whole new tranny because my manual was not designed to mate to a T-case.
Robert 1975 C10 - Huckleberry 2007 Jeep JK - John Wayne Jeep Smittybilt front/rear bumper, 10K winch Pacific Grove, CA |
10-28-2014, 10:26 AM | #6 |
78K & 79C Jimmys
well the burb,pickup,jimmy frames are different.
so are the body mounts/floor pans. working back from 4X4 to 4X2 would be the way to go. I'd bet you could sell off any 4X4 stuff easy,I'd go that way
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
10-28-2014, 04:15 PM | #7 |
It'd be alot cooler if you did
find one and buy it... always the easiest route for me!
10-29-2014, 02:57 AM | #8 |
A few have took a 4x4 one and swapped it over to 2wd.Its not hard its all bolt in just a big job since your taking out the whole suspension in it.The front its engine crossmember and whole steering besides the leaf springs and hangs.And you can use a pickup for the front parts not sure about the rear leaf spring size on a 2wd blazer.
10-29-2014, 08:45 AM | #9 |
The 2wd Blazers are not that hard to find....there was one on kijiji for 1500.00 a couple of weeks ago;your best option is to do a frame swap with one.We did a 91 Blazer 4wd to 2wd a few years ago;Used an 81 frame;trans from a 2wd 90 suburban;kept the efi etc;worked out just as if the factory had done a 2wd Blazer.
10-29-2014, 10:58 AM | #10 |
Well I was hoping not to have to buy one as I've got 2 blazers and multiple suburbans and trucks! But if I come across a 2wheel drive blazer I might have to buy it haha
