Loves all GMC trucks
![]() Join Date: Jul 2010
Question for the welding pros
I went to my parents house this weekend for their neighbors funeral. My dad asked if I would use his old stick welder if he gave it to me and of course I said yes.
I already have a new Hobart 190 for mig but thought this would add to my capability. it's an old miller thunderbolt 225. My question is this... 1. What maintenance do I need to do to it before I use it? It has set for several years (7-10). I thought I could use it on heavy frame welding. 2. Is it even safe to try and use it? I know it works (or should) he just hasn't needed it. I'm new to welding but always looking to learn. 3. About what year is this model and can I find the user manual? I'll google for the manual! I appreciate anyone thoughts or criticism on it's use.
Mike If your helping someone and expecting something in return... your doing business not kindness! |
Re: Question for the welding pros
they can b used with good results for heavier frame work// the main thing with stick welders is to use freash sticks as they can and do go bad due to humidity and storage
#3 | |
Should I just open it up and do a general cleaning inside the unit? Thanks for the reply.
imo... there is nothing on a any truck that will be over 10 gauge steel,
your hobart 190 mig will handle anything on any vehicle without a problem i learned to stick weld with dc arc welders, ac arc welders are a lot harder to weld consistent with your hobart 190 probably has a 30 amp 220v plug, this miller will need a 50 amp plug hooked up with #8 wire again imo... don't bother. sell it or give it back to dad
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#5 | |
hardly a space shuttle
meowMEOWmeowMEOW
Guys use stuff like that to repair steel trailers and farm equipment and such. The only downside is that with how cheap buzzbox's have become, there isn't a reason for a small-time user to buy a machine of that size/capability.
...and anyone needing that large of a machine probably already has something more modern for production. That being said, we backhalfed my old S10 with a stick and it was pretty good (and VERRRRRY strong). Pics from like 2006 ![]() ![]()
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Thanks br3w city and guys!
Well since I live in the middle of nowhere... and all my neighbors are farmers except the 5 houses around mine... I guess I can help them out after I borrow and break their tractors! LOL. Seriously though, thanks for the input. It's very old but I wasn't turning my dad down cause he loves that I build, play and tear apart the trucks he built for over 32 years. I'll keep this thing for the building/garage next year. No one has yet to tell me if I should clean it up before I try to use it. I guess I'll leave it packed away until it's closer to time to use it. Like you said the 190 should be able to do anything I need!
Think of it as garage art from your Dad. I have a number of unused tools from my father-in-law
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
That welder has its place but automotive isn't it. Its awesome for welding heavy thick steel but your 190amp mig will more than handle anything automotive based. Those old welders were built to last and you cant buy something now that will last as long as long as that one. There really isn't a whole to do to clean anything up. The most I would even consider is to just blow the dust out with shop air.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#11 | ||
though it may be older than you...
that welder is ''relatively'' new and has aluminum windings in it it also has a 20% duty cycle and really won't work for heavy welding unless your heavy welding is 6'' ![]() unless you have lots of room, scrap or sell it you'd get more for scrap than you could on craigslist or ebay
#13 |
2WD Jimmy
![]() Join Date: Mar 2005
[QUOTE=
it also has a 20% duty cycle [/QUOTE] Yes... At 200 Amps. ... Look, that is a great little stick welder. Sure, its not for sheet metal, but you can use it for alot of things. I would keep it and use it. |
#14 | ||
#15 | |
Parts and more parts
That being stated, I grew up on a farm and the stick welder was the big thing during my youth. Every farm boy knew how to weld and was very good at it. I went to work at a County Highway department and spent a lot of time doing welding on the heavy equipment and doing hard surfacing on the rock crusher parts to make them last. Wire welding was invented after my younger years. Wire welding in my time was an acetylene torch and bailing wire. Don't live in Matfield anymore, and I make an effort to blink when I drive by on the Turnpike, but then again it was home. That being stated, I now have a Miller 220 welder and a plasma cutter, both of which I hardly use, but when needed, I can get them going.
Frank |
#16 |
you could always turn it into a tig.. 100 bucks for a torch and another bottle and your off to the races.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
#17 | ||
I already have a 330cf cylinder or 100% argon. Plus I have a crisp $100 bill! Lol
#18 |
Wow, I had no idea this was possible! I'm reading tons of info now. Yes google is my friend... but if you don't know something's possible, you'll never learn.
Thanks for the info. Here a link I'm watching. http://weldingweb.com/showthread.php...to-TIG-welding
#19 |
set it to dc neg, torch lead goes to stinger, need to get a torch with a manual gas knob on it.. well you don't have to but it's a lot better/easier.. hook up the gas feed, ground it.. starting welding..
there's lots of torches ebay, prob a few on craigslist in your area as well lots on videos on youtube about it as well, just look for scratch start tig.
#20 | |
I'm learning a lot and will look into this after I drag home my AV Gas refueler.
#21 |
#22 |
ooppps i thought all tunderbolts were ac/dc..
my bad... nvm on the tig then.. wont work.
#23 |
![]() Join Date: Aug 2014
I will throw my input in as my family owns a steel fab shop. Like others have said it is great for heavy steel, but not the best for automotive. Honestly if you where closer and if we didn't already have at least 15 welders ranging from small machines to 400 amp diesel powered welders i would buy it off of you. The comment about the humidity with welding rods only has to do with one type of rod. I can't remember off the top of my head as i don't do much welding, but will ask my dad who is a master welder when he gets home. We actually have a rod heater for that type of rod that is like a little oven to keep the rods dry.
If you or anybody ever has any questions about welding PM me and i will ask my dad and you will get the correct answer. He has been welding professionaly for 30+ years and started the buisness when he was in his 20's. I am only 21 and haven't had time to get certified and take any classes for welding as i just got out of truck driving school earlier this year. |
#24 |
I asked my dad and he said the 7018 rods are the ones with the humidity problems.
