Fuel Filler Neck rusted out
Well, sad day. I was going to put in my new gas tank but thought I better check out my filler neck since it had some other rusty pieces around it and sure enough, discovered a large hole right where it meets the floor and has the gasket around it.
So, other than buying a used one from the forum, what are my options? Is it possible to clean it up and weld a new section on? What have you guys done in the passed?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
Re: Fuel Filler Neck rusted out
Normally, i would say go for the fix, but, that area has a reduced shoulder at the bend....could be difficult and time consuming to weld or solder
Since these parts are accessible in the parts forum, JMHO, but it may be an easier fix to buy a used one.....unusual place for rust to appear, never seen that before. I guess the gasket held water
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
I'm not surprised that it was rusted out. I'm thinking if I do attempt to fix it, I'll cut it way back to near the top, and weld on from there, but I will try to locate one before I attempt it
#4 | |
Korinek or tee it up, would be a good place to start. If i had one, i d ship it to you Nice looking Jimmy
![]() Join Date: May 2011
87 Skier sent you a pm
Since you're relatively near-by in Corvallis, i can bend a 1.25" tube 90* and give it to you. Or I could weld it in if you need. I probably have some in the cut pile.
Just another option.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744 |
I appreciate the offer, but I found one in the classifieds.
For now, this one is going on my wall of shame (all the "cool" crap that have come off my vehicles) Thank you again for offering!
