10-20-2014, 02:10 PM | #1 |
1978 Specifics
Hello all, I'm looking at two 1978 K10 Chevrolets and trying to decide if I should buy one of them. Oddly enough they are both asking $2k and are equal drives from my house. I don't know a ton of specifics about that generation of trucks and was hoping I could get some info from the collective knowledge here. I'm just wanting one for a project and then as a weekend/play-around truck (no extreme mudding or rock crawling or anything).
Since they are both '78s, what features made that year different than any other? Was it a good year overall? Is that a fair price for this year? One is a 3-speed and the other is a 4-speed (both manual). Is one significantly worse/better than the other? I don't know the gearing on either sadly. |
10-20-2014, 03:21 PM | #2 |
Re: 1978 Specifics
Like most GM trucks from the 70's, 1978's are prone to rust. Bottoms of fenders, rocker panels, cab corners, etc. Be on the lookout for that.
Exterior-wise, they are pretty much identical to 1977's. Interior changes were made in 1978, however. The wood paneling inside was gone, replaced with brushed metal trim (simulated of course), and a new instrument bezel was installed. On the other hand, 1978 was the last year of the old style gas cap, as it was changed to a fuel door in 79 (if the filler is stock on those trucks, that is). Take a look at this link, it should give you a lot of information on '78's. http://www.oldcarbrochures.com/stati.../dirindex.html
Cameron 1984 Chevy C20 Custom Deluxe |
10-20-2014, 03:23 PM | #3 |
Re: 1978 Specifics
...oh and I forgot, 1978 was the first year of the newer style steering wheel, two types, depending on the trim level.
10-20-2014, 03:44 PM | #4 | |
Re: 1978 Specifics
Pretty much the same from '73 - 87 ('73 to '80 are even more similar).
The 4 speed (on the floor, I presume) would be the SM465, which has the unsynchronized 6:1 creeper first gear is is better for pulling stumps or launching heavy trailers. Here's the generic info packet for a '78, courtesy of the GM Heritage Center archive. https://www.gmheritagecenter.com/doc...olet-Truck.pdf K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-20-2014 at 03:56 PM. |
10-21-2014, 10:17 AM | #5 |
78K & 79C Jimmys
Re: 1978 Specifics
some 78 info I believe correct
78 finished the orange block 350s later ones blue 78 finished the glass fuses. first year of changes that carry threw later years
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
