1972 Oil fill cap?
On my small block valve covers, I was wondering if the oil fill cap was chrome painted or what?
Any pictures of OEM ones would be great too. Thanks. |
Re: 1972 Oil fill cap?
here's mine after a repaint of the engine. originally painted so went back the same.
1970 GMC Custom 1500 SWB 307/TH350 3.73 Positrac |
It should be a rubber oil fill cap. If you had power brakes then you also would have had the oil fill extension tube on the drivers side.
I don t believe the metal oil fill cap is original to our trucks. |
this is the correct explanation
![]() Join Date: May 2012
Although the extension is an add on. I have a metal cap near the fire wall. When the engine was replaced with a re-manufactured 350 long block, back in 1990, all the existing parts were re-used with the long block.
Certainly don't mean to mislead. My truck did not originally have the brake booster (i added it along w/ power steering and TH350 during a frame off this past year). I switched the valve covers which put the oil fill on the front right instead of the driver rear to allow more room. However, i don't have any reason to believe the fill cap isn't original as it was an unmodified family vehicle.
Rubber oil fill caps on my '72 C20 with a 350.
Does anyone know where to buy a new rubber oil fill cap that fits under the A/C bracket? |
According to my Chassis and Body Parts Catalog, the correct cap for 71-72 is part number 3980273, a push in oil cap, made of rubber. These are widely available in NOS form and reproduction. GM used these on lots of cars & trucks beginning in 1971.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#9 | |
![]() Join Date: May 2010
Moderator
![]() Join Date: May 2007
The rubber cap is available in the HELP section of most parts stores.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
So things don't get too confused. I should not have posted. Mine is a 1970. Sorry for interjecting!
Neither should I. Wasn't aware there were differences year to year.
#13 | |
Information regarding other years is great, but slightly off topic. |
#14 | |
#15 | |
Off topic? Maybe slightly. But, I think the info was relevant for future readers. Sorry if this caused any confusion. Does anyone know if the rubber caps were painted? I've seen them both ways. I'd think not since the oil tubes (when used) were black. Or, were the caps in the valve cover when the engine was painted and the tubes added later on the assembly line? Last edited by FirstOwner69; 10-22-2014 at 11:42 AM. |
