Old 10-21-2014, 12:28 AM   #1
ZMAR
ZMAR's Avatar
Dual headlight wiring question
I got the complete harness from an 88 suburban for my swap on my 84 k30. I removed the old harness and just plugged the new one in. Hooked lights to it and NOTHING works. Headlights, parking lights, blinkers, nada. Am I supposed to just splice the pigtails off the 88 harness to make it work? So much for plug and play... All I need is this resolved and I'll be up and running again!
71 c10 swb
ZMAR is offline   Reply With Quote
Old 10-21-2014, 12:29 AM   #2
ZMAR
ZMAR's Avatar
Re: Dual headlight wiring question
71 c10 swb
Old 10-21-2014, 02:01 AM   #3
y5mgisi
Second Chance Program
y5mgisi's Avatar
Not much help for you, but i really like the truck! Sure you didnt miss a ground?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-21-2014, 06:50 AM   #4
homemade87
My vote would be you did not get the grounds hooked up or a bad ground connection . If nothing works this is the common denominator . Also never overlook power source . Throw a meter on it. Get it fixed and get it on the road. I love driving mine.
homemade87 is offline   Reply With Quote
Old 10-21-2014, 10:05 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
I'd check the wire colours in the plug?
not all plugs get wired the same
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-21-2014, 12:03 PM   #6
ZMAR
ZMAR's Avatar
Ok guys thank yall. I'll keep yall updated
71 c10 swb
Old 10-22-2014, 09:02 PM   #7
ZMAR
ZMAR's Avatar
Well I checked and rechecked the grounds and here we go!
71 c10 swb
Old 10-22-2014, 09:10 PM   #8
ZMAR
ZMAR's Avatar
Would anyone know why my front right blinker stays lit? The rear doesn't until I engage the signal. It just stays lit and doesn't blink on the rear.
71 c10 swb
Old 10-23-2014, 07:29 AM   #9
homemade87
It does sound like the pins in the plug is still off. I would recheck them . Also I see your bottom head light is burning. Just on dim the top should be burning. On bright all four. The top bulb should have 3-connectors on it and bottom have 2-connectors.
Old 10-23-2014, 08:00 AM   #10
ZMAR
ZMAR's Avatar
Yessir that's how I have it set up but it seems to only work like this. I will clean all the connections and see what that does. Anything else I should look for?
71 c10 swb
Old 10-23-2014, 09:18 AM   #11
Billett
Billett's Avatar
I'm sub'd. We just picked up our first 73-87 for my younger brother and are trying to get it running for his birthday this weekend to go wheeling. The PO blew the dimmer switch and just threw in a toggle to replace it, but the whole setup is a huge mess. I added in relays for the quad setup, but I've been getting some weird problems just like yours, with only the bottom coming on instead of the top. Also had issues where the circuit for all four would only turn on the top two, the opposite circuit would turn on the bottom two, but both together light all four. The way its wired makes me think the one circuit should light all four... My older brother supposedly got it working last night, so when I head home today I'll try to get some pics of what we did.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 10-23-2014, 09:32 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
this is stock,but you can put the bulbs low/low(3pin),high/high(2pin)
If that's what you want,I did it to mine
just bend out the corners of the buckets,to prevent going cross eyed lol
may want to remove the wires from the plastic plugs,check for corrosion.
check the front marker bulbs base wires,and confirm no rears bulbs are reversed
John
Old 10-24-2014, 06:55 AM   #13
ZMAR
ZMAR's Avatar
Let me know what you got figured out!
71 c10 swb
Old 10-24-2014, 06:56 AM   #14
ZMAR
ZMAR's Avatar
I just took the front bulb out and cleaned the socket really good works like a champ now.
71 c10 swb
