10-21-2014, 01:55 AM | #1 |
Nv 4500
I have a 1993 NV4500 2wd 5 speed overdrive. chevy input and bolt pattern .400 style spline on rear shaft is from a p30 van 13 inch tail shaft .Transgo rebuilt with 0 miles.Lake wood blow proof bell housing bored and drilled to fit the trans Set up for mechanical or hydraulic clutch fork on drivers side with shifter and flywheel and clutch.1200 .00
10-21-2014, 05:01 AM | #2 |
Re: Nv 4500
Where are you located?
10-21-2014, 07:54 PM | #3 |
Re: Nv 4500
Im in Md 21921 zip i would be willing to put it on a pallet but have no way of weighing it or any of that id imagine it would be costly to ship .Its a great set up i just got a great deal on a Tremec 5 speed.
10-25-2014, 01:51 PM | #4 |
Re: Nv 4500
Still for sale great set up!
10-25-2014, 11:04 PM | #5 |
Re: Nv 4500
what would I need to get this in my 71 c20 with 350 and sm465. just curious if you know off hand
10-26-2014, 08:37 PM | #6 |
Re: Nv 4500
It bolts in normally like any 4 or 5 speed manual.It comes with everything needed you might have to shorten your drive shaft i suppose.
10-26-2014, 10:06 PM | #7 |
Re: Nv 4500
and what about the speedo??
10-26-2014, 11:41 PM | #8 |
Re: Nv 4500
Either change the mainshaft to one with a mechanical drive or use a converter or put a electronic speedo in it has the vss plug on the tail shaft .The gps speedos are reasonable and work well also lots of guys i know use them in street rods.
