Old 10-21-2014, 01:28 PM   #1
Cam1968rsss
1972 C10 Upper Control Arms & Emergency Brake Pic
Hi all, do any of you have a good picture you could share that would show a upper control arm on a 1972 C10 where the shims go on between the control arm and the frame? Am trying to get mine right and I have some spacers but sure if any go there with the shims? Also if anyone has a good picture of the rear emergency brake cables hooking up to the brakes inside the brake shoes I would appreciate that also...
Eddie
Cam1968rsss is offline   Reply With Quote
Old 11-26-2014, 10:12 PM   #2
Rod Run
Rod Run's Avatar
Re: 1972 C10 Upper Control Arms & Emergency Brake Pic
I just started getting my rear-end ready for paint, before re-assembly. If I was a little further along I could help you out.
Sorry that I can't, but maybe this will help bump your thread up to the top so others will see it and can help you though.
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
