10-21-2014, 01:33 PM | #1 |
Removing side trim from 65 chevy pickup
How do you remove the side trim from 65 C10 chevy truck? Trying to get everything removed so I can take pics to sell. Thanks for any help.
Edit: I did a search before my post but, didn't find anything about removal of side trim. Bump...anyone? Last edited by '65 chevy lover; 10-21-2014 at 09:28 PM. |
10-21-2014, 09:45 PM | #2 |
Re: Removing side trim from 65 chevy pickup
its just clipped into holes drilled in the side sheetmetal so you can get a putty knife behind it and feel for the spring clip and pop pop pop all the way down.
except the 4 cab pieces are attached from inside the cab, you cant pop those off unless you like bent pieces. Its why trim sets sell without those pieces because once guys bend them they are junk. use extra care removing the 4 small cab pieces behind the door.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
10-21-2014, 10:02 PM | #3 |
Thank you for asking that question. Once you get them off let me know if you need a buyer. I need a set for my 64.
10-21-2014, 10:54 PM | #4 | |
10-21-2014, 11:05 PM | #5 |
1961 crewcab
fenders are bolted on, (the clips) the bed has the plastic clips, which will probably break as you take them off, might double check your doors, can't remember if they were plastic, or bolted.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
10-21-2014, 11:10 PM | #6 |
