Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-15-2003, 04:30 AM   #1
ronsk10
wtb gastank
I need a 16 gallon gas tank for a 85 4x4 SWB. Thanks
ronsk10 is offline   Reply With Quote
Old 08-15-2003, 06:53 AM   #2
Poonman86
where u located? I have one out of an 86
Poonman86 is offline   Reply With Quote
Old 08-15-2003, 09:24 AM   #3
bigblock73
yeller
bigblock73's Avatar
Yeah, where do you live and what side are you looking for? I have one as well...off an AZ truck.
-Jeff
bigblock73 is offline   Reply With Quote
Old 08-15-2003, 06:42 PM   #4
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I have one in KY for drivers side!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 08-15-2003, 09:58 PM   #5
ronsk10
I am in NC 27874. I am told that either side would fit just reverse the straps but it is a driverside. Thanks. also send prices
Old 08-16-2003, 09:13 PM   #6
bigblock73
yeller
bigblock73's Avatar
Left and right tanks are different and won't interchange I don't think. The tanks themselves are shaped differently on one end to fit inder the cab and the opposite end that goes under the bed is larger.
-Jeff
Old 08-16-2003, 10:46 PM   #7
BigBlockBurris
BigBlockBurris's Avatar
Ron,
Where in NC are you? I have several. E-mail me at mburris@carolina.rr.com and we'll work out the details.
BBB
BigBlockBurris is offline   Reply With Quote
Old 08-19-2003, 12:08 AM   #8
ronsk10
still looking for a tank.
Old 08-25-2003, 12:19 PM   #9
Poonman86
sent you an email
Old 08-25-2003, 06:15 PM   #10
phantom dually
I was told they would fit either side also
Old 08-28-2003, 01:29 PM   #11
tibbar
Tank
73-86 tanks were designed to be installed on either side of the vehicle. Flip the straps and tank will fit other side. Good luck Tibbar
tibbar is offline   Reply With Quote
Old 08-29-2003, 12:43 PM   #12
rodkeyc
is it possible to mount a 73-91 chevy blazer tank to the truck to reposistion it within the frame instead of the saddlebag style?
I would rather push my chevy than drive anything else.
rodkeyc is offline   Reply With Quote
Old 08-29-2003, 02:01 PM   #13
tibbar
gas tank
If you don't have a spare tire mount under there. Then yes it is fairly easy. The only problem is the filler neck. Have installed tubes and put the neck back at the factory location, or some people put it in the wheel well. Others cut the fill panel out of a suburban or blazer and put it on a pickup for the custom look.
These tanks are fairly universal, so you can put the neck where you want.
Good luck Tibbar
Old 09-05-2003, 08:35 AM   #14
rodkeyc
thanks for the reply tibbar. good advice.
