Old 10-21-2014, 09:25 PM   #1
Mv7fd
Helicoil crank snout
Like a dumb dumb I tried to use the harmonic balancer bolt to pull the balancer on now I need a helicoil or maybe a little longer bolt not sure the longer bolt will work. Has anyone done this before and should I stay with the 7/16x20 or go to the 1/2x20 or go with a course thread bolt size
Mv7fd is offline   Reply With Quote
Old 10-21-2014, 09:48 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Helicoil crank snout
1/2 20 is an easy drill and tap
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 10-21-2014, 09:54 PM   #3
Just call me Sean
Just call me Sean's Avatar
That's how I put my balancers on.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 10-21-2014, 10:05 PM   #4
Mv7fd
Well it didn't work for me. That thing was super tight to get on
Old 10-21-2014, 10:18 PM   #5
Blown06
Blown06's Avatar
I would Heli-coil it, I know you'll almost be at 1/2" when you install the coil but if you or anyone else tears down the engine in the future it will still be running a factory sized bolt on the balancer. My two cents, good luck with the repair.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 10-21-2014, 10:48 PM   #6
chrly1492
take another look, usually the balancer bolt isn't long enough and it damages the end threads in the crank...chase the threads with a good bottoming tap, but get a kit that has fine all thread, and use a nut and washer to pull the balancer into place. Be sure and run the all thread as far into the crank as possible before using the nut and washer. Good luck..also make sure that it is a hardened washer, not something in the tool box..a grade 3 for instance will just crush.
chrly1492 is offline   Reply With Quote
Old 10-22-2014, 12:43 AM   #7
kalbert
The parts store might rent you an installer, maybe even for free. It'll have the thrust bearing and the balancer will glide on like warm butter. Comments about only the first bit of threads being wiped out are probably right. Try chasing with a tap and then turn a new bolt in all the way and see how it goes. Heli Coil will work too, it'll keep you with the common bolt size and possibly be stronger.
kalbert is offline   Reply With Quote
Old 10-22-2014, 06:01 AM   #8
Mv7fd
I bought the install tool for the balancer after I messed up the threads so the balancer is on now I just have to fix my screw up. I ran a tap in it several times and I can almost get the bolt tight and then that last little bit it'll spin easy right where it should torque Down
Old 10-22-2014, 09:56 AM   #9
Mv7fd
Is the end of the harmonic balancer when fulley seated suppose to be flush with the end of the crank or no
Old 10-22-2014, 10:23 AM   #10
jetmech85
No, it will bottom out on the timing gear before it is flush.
jetmech85 is offline   Reply With Quote
Old 10-22-2014, 11:25 AM   #11
Jake Wade
Jake Wade's Avatar
Wrong way to do it, you have been very lucky.
Its OK to use a stud and nut, big difference than using a bolt.
Best way is the correct tool:
http://www.summitracing.com/parts/mor-61740/overview/
Jake Wade is offline   Reply With Quote
Old 10-22-2014, 11:41 AM   #12
Mv7fd
Can you double stack a helicoil to get more length so you know you got the bad threads covered
Old 10-22-2014, 02:44 PM   #13
cadillac_al
I bought a crank kit once and when it was all installed I found out the balancer threads were messed up. I didn't want to take the engine apart again so I got a slightly longer bolt and was able to use it. Usually only the first few thread get damaged anyway.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-22-2014, 07:13 PM   #14
Just call me Sean
Been lucky for many years.
Old 10-22-2014, 08:20 PM   #15
Mv7fd
Longer bolt worked like a charm
Old 10-22-2014, 08:22 PM   #16
Blown06
Blown06's Avatar
Good deal, glad it was a good outcome. Beats the heck out of yanking the motor back out.
Me: Jarrod
